1 | | | | 7000 Quadrupole MS/MS EI System | | 1 |
| | | | 7000B 三重串联四极杆质谱仪(包括主机、EI源、离子 | |
| | | | 压力控制器,MassHunter 数据软件,电脑,打印机) | |
2 | | | | Agilent 7890A gc for MS with SSL inlet | | 1 |
| | | | 7890A气相色谱(包括与MS连接的分流/不分流进样口) | |
3 | | | | Capillary S/Sl inlet with EPC | | 1 |
| | | | 分流不分流进样口 | | |
4 | | | | FID w/EPC, for capillary column only | | 1 |
| | | | FID检测器,带EPC | | |
5 | | | | Micro Electron Capture Detector with EPC | | 1 |
| | | | ECD,带EPC | | |
6 | | | | Install Kit for gcs w/out Gas Purifiers | | 1 |
| | | | 安装工具包 | | | |
7 | | | | Trap, O2/H2O, 1/8" | | 1 |
| | | | 氧水捕集阱 | | | |
8 | | | | 7693A Autoinjector | | 1 |
| | | | 16位自动进样器 | | |
9 | | | | 7693A Tray, 150 Vial | | 1 |
| | | | 150进样盘 | | | |
10 | | | | NIST 2008 MS Library Bundle | | 1 |
| | | | "最新NIST08标准谱库、化学结构库,包括17.5万张谱图和14.7万张结构图 |
11 | | | | Syr. 10ul tapered, FN 23-26s/42/HP, 6/PK | | 1 |
| | | | 自动进样器针,6/PK 锥形 | | |
12 | | | | Screw cap vials, clear 100/PK | | 1 |
| | | | 螺纹口样品瓶,100/包 | | |
13 | | | | Non-Stick BTO Inlet Septa 11mm 50 pk | | 1 |
| | | | 低流失进样隔垫, 50/包 | | |
14 | | | | Column nut 2/PK | | 1 |
| | | | 柱接头 | | | |
15 | | | | Ferrule Graphite 320um 0.5mm id 10/PK | | 1 |
| | | | 石墨密封垫,10/包 | | |
16 | | | | Lnr,gen purp split/spltls,tpr,glswl,deac | | 1 |
| | | | 分流/不分流衬管, 5/包 | | |
17 | | | | 0.4mm; 200,250um ferrules 10/PK | | 1 |
| | | | 密封垫,10个/包 | | |
18 | | | | Column nut fitting | | 1 |
| | | | 柱接头 | | | |
19 | | | | HP-5MS 30m, 0.25mm, 0.25u | | 1 |
| | | | HP-5MS 30m, 0.25mm, 0.25u色谱柱 | | |
| | | | 国内采购部分: | | |
| | | | 高纯氮气钢瓶及减压阀 | | 1 |
| | | | 高纯氢气钢瓶及减压阀 | | 1 |
| | | | 空气钢瓶及减压阀 | | 1 |
| | | | 氦气钢瓶及减压阀 | | 1 |
| | | | 甲烷气钢瓶及减压阀 | | 1 |
| | | | 10KVA延迟2小时 | | 1 |
| | | | 1、提供现场安装、调试、操作培训。 | | |
| | | | 2、保修期壹年(安装调试结束之日起计算)。 | |
| | | | 3、供货期:合同生效后90天内。 | | |
| | | | 4、付款方式:100%LC或100%T/T。 | | |
