【资料】2011年6月的Erice Crystallography School的资料
X射线衍射仪(XRD)
  • [1] International School of Crystallography:
    课程介绍:http://www.crystalerice.org/Erice2011/2011pd.htm
    教学PPT/PDF:http://erice2011.docking.org/upload/Erice_PD_School_2011/
    教学视频:http://www.ustream.tv/channel/erice2011pd/videos
    授课老师:
    Yuri Andreev (UK) #
    Christian Baerlocher (CH) #
    Joel Bernstein (IL) #
    Simon Billinge (US) #
    Radovan Cerny (CH) #
    Laurent Chapon (UK) #
    Robert Dinnebier (DE) #
    Yaroslav Filinchuk (FR) #
    Andy Fitch (FR) #
    Carmelo Giacovazzo (IT) #
    Chris Gilmore (UK) #
    Fabia Gozzo (CH) #
    Martin Jones (UK) #
    Arnt Kern (DE) #
    Winfried Kockelmann (UK) #
    Matteo Leoni (IT) #
    Luca Lutterotti (IT) #
    Ian Madsen (AU) #
    Irene Margiolaki (FR) #
    Lynne McCusker (CH) #
    Lukas Palatinus(CH) #
    Colin Pulham (UK) #
    Lubo Smrcok (SL) #
    Peter Stephens (US) #
    Tamas Ungar (H) #
    Bob von Dreele (US) #
    Xun-Li Wang (US) #
    Pamela Whitfield (CA) #
    Jon Wright (FR) #
    授课内容:
    Fundamentals of Powder Diffraction
    Experimental Techniques
    Progress in Instrumentation
    Developments in Structure Solution Methods
    Interaction with EM, Spectroscopy, Thermodynamics, Computation
    ,Perfection and Imperfection
    Quantitative Phase Analysis
    Texture Analysis
    Beyond Traditional Applications
    [2] International School of Crystallography:
    课程介绍:http://www.crystalerice.org/Erice2011/2011ec.htm
    教学PPT/PDF:http://erice2011.docking.org/upload/Erice_EC_School_2011/
    教学视频:http://www.ustream.tv/channel/erice2011ec/videos
    授课老师:
    Jan Pieter Abrahams, NL #
    Anatoly Avilov, RU #
    Christian Baerlocher, CH #
    Rafal-Dunin Borkowski, DK #
    Gianluca Cascarano, IT #
    Felix Chukhovskii, RU #
    Robert Dinnebier, DE #
    Mauro Gemmi, IT #
    Carmelo Giacovazzo, IT #
    Christopher Gilmore, UK #
    Tatiana Gorelik, DE #
    Joke Haderman, BE #
    Sven Hovmoller, SE #
    Martin Hytch, FR #
    Jacob Jansen, NL #
    Bruno Janssens, BE #
    Ute Kaiser, DE #
    Christoph Koch, DE #
    Ondrej Krivanek, USA #
    Lawrence D. Marks, US #
    Jean Paul Morniroli, FR #
    Peter Mueller, USA #
    Stavros Nikolopoulos, BE #
    Peter Oleynikov, SE #
    Lukas Palatinus, CZ #
    Stefano Rubino, SE #
    Peter Schattschneider, AT #
    Martin U. Schmidt, DE #
    Kenneth Shankland, UK #
    Andrew Stewart, DE #
    Kenij Tsuda, JP #
    Marin Van Heel, UK #
    Dirk Van Dyck, BE #
    Yimei Zhu, US #
    授课内容:
    Phase problem and different approaches for structure solution
    Image formation in the electron microscope
    PED and ADT
    Quantitative 3D electron diffraction data by precession and electron rotation method
    Combination of X-ray powder diffraction, electron diffraction and HRTEM data
    Structure solution via strong reflections approach
    Prospects for structure solution by electron diffraction of 3D protein crystals
    Diffractive electron imaging on nanoparticles
    Shadow imaging for charge distribution analysis
    Commensurate and incommensurate superstructures via electron diffraction
    Image contrast in atomic resolution high-angle annular dark-field images
    Simulations of electron diffraction patterns
    In-situ transmission electron microscopy and theoretical studies on the coalescence of nanoparticles
    这是转的小木虫晶体版上一帖子.
  • 大陆
    第1楼2011/06/23
    马普固体所的Dinnebier做的报告值得一看。
  • 该帖子已被版主-xujun16加2积分,加2经验;加分理由:谢谢,大陆老师推荐!
  • 大陆
    第2楼2011/06/23
    下面这个视频也很有意思,热振动的图像,时间被拉到ps。
    [flash=480,400]http://ng1.17img.cn/bbsfiles/images/2017/10/201106231405579273_01_0_3.swf[/flash]
  • 大陆
    第3楼2011/06/23
    Heel关于傅立叶变换的相位的形象揭示让人印象深刻:
    首先出场:实空间中的 爱因斯坦 VS 玛丽莲
  • 大陆
    第4楼2011/06/23
    帅哥、美女的倒空间幅值与相位分别如下:
    注意幅值图是中心对称而相位图是反中心对称的。
    不难想象,倒空间的幅值、相位如果没有弄错的话,它们分别能够准确无误的还原成帅哥和美女。
  • 大陆
    第5楼2011/06/23
    如果在逆傅立叶变换过程中不小心把相位与幅值搞混了,结果如何呢?哈哈,请看:
  • 大陆
    第6楼2011/06/23
    另外,我们知道,复数可表示成幅值(相位),亦可等效表示成实部+i虚部的形式,如果我们将帅哥与美女的倒空间以实部/虚部的数学形式表达,然后再变换到实空间。当然,如果逆傅立叶变换过程中实部与虚部没有搞错的话,对应的能还原成帅哥、美女。
  • 大陆
    第7楼2011/06/23
    但是,如果非常不小心把实部、虚部搞混了,结果将是非常的不幸……请不要轻易尝试去看:
  • 大陆
    第8楼2011/06/23
    所以建议有兴趣的朋友不要尝试将你或自己爱人的照片在倒空间里搞混实部和虚部,呵呵。
  • iangie
    第9楼2011/06/23
    .........大陆老师表灌水.......这是电子晶体学那部分的内容吧.....-_-|||
  • 大陆
    第10楼2011/06/23
    在解结构这个问题上,倒空间的结构因子幅值及其相位与实空间的电子云分布的相互变换原理是互通的,没有电子或X-ray的区别。
    如果你把上面的图片看成电子云在空间某截面的分布,你就不认为我是在灌水了,呵呵。
    iangie(iangie) 发表:这是电子晶体学那部分的内容吧
