camellia1014
第1楼2006/02/17
4. 材料和方法
4.1 写作要点 (1) 对材料的描述应清楚、准确。材料描述中应该清楚地指出研究的对象(样品或产品、动物、植物、病人)的数量、来源和准备方法。对于实验材料的名称,应采用国际同行所熟悉的通用名,尽量避免使用只有作者所在国家的人所熟悉
专门名称。(2) 对方法的描述要详略得当、重点突出。 应遵循的原则是给出足够的细节信息以便让同行能够重复实验,避免混入有关结果或发现方面的内容。如果方法新颖、且不曾发表过,应提供所有必需的细节;如果所采用的方法已经公开报道过,引
用相关的文献即可(如果报道该方法期刊的影响力很有限,可稍加详细地描述)。(3) 力求语法正确、描述准确。由于材料和方法部分通常需要描述很多的内容,因此通常需要采用很简洁的语言,故使用精确的英语描述材料和方法是十分重要的。需要注意的方面通常有:(a)不要遗漏动作的执行者如:“To determine its respiratory quotient, the organism was...”显然,the organism不能来determine?又如:“Having completed the study, the bacteria were of no further interest.”显然,the bacteria不会来completed the study.(b)在简洁表达的同时要注意内容方面的逻辑性如:“Blood samples were taken from 48 informed and consenting patients...the subjects ranged in age from 6 months to 22 years”,其中的语法没有错误,但6 months的婴儿能表达informed consent?(c)如果有多种可供选择的方法能采用,在引用文献时提及一下具体的方法如:“cells were broken by as previously described[9]”不够清楚,应改为:“cells were broken by ultrasonic treatment as previously described[9]”.
4.2 时态与语态的运用 (1) 若描述的内容为不受时间影响的事实:一般现在时。如: A twin-lens reflex camera is actually a combination of two separate camera boxes. (2) 若描述的内容为特定、过去的行为或事件,则采用过去式。如:The work was carried out on the Imperial College gas atomizer, which has been described in detail elsewhere[4,5]. (3) 方法章节的焦点在于描述实验中所进行的每个步骤以及所采用的材料,由于所涉及的行为与材料是讨论的焦点,而且读者已知道进行这些行为和采用这些材料的人就是作者自己,因而一般都习惯采用被动语态。例如:优:The samples were immersed in an ultrasonic bath for 3minutes in acetone followed by 10minutes in distilled water. 劣:We immersed the samples in an ultrasonic bath for 3 minutes in acetone followed by 10 minutes in distilled water. (4) 如果涉及表达作者的观点或看法,则应采用主动语态,如优:For the second trial, the apparatus was covered by a sheet of plastic. We believed this modification would reduce the amount of scattering. 优:For the second trial, the apparatus was covered by a sheet of plastic to reduce the amount of scattering. 劣:For the second trial, the apparatus was covered by a sheet of plastic. It was believed that this modification would reduce the amount of scattering.
5 研究结果
5.1 写作要点 (1) 可根据需要建议建议作者是否合并“结果”(Result)与“讨论”(Discussion)。(2) 对实验或观察结果的表达要高度概括和提炼,不能简单地将实验记录数据或观察事实堆积到论文中,尤其是要突出有科学意义和具代表性的数据,而不是没完没了地重复一般性数据。(3) 数据表达可采用文字与图表相结合的形式。如果只有一个或很少的测定结果,在正文中用文字描述即可;如果数据较多,可采用图表形式来完整、详细的表述,文字部分则用来指出图表中资料的重要特性或趋势。切忌在文字中简单地重复图表中的数据,而忽略叙述其趋势、意义以及相关推论。(4) 适当解释原始数据,以帮助读者的理解。如果论文中还包括独立的“讨论”章节,应将对于研究结果的详细讨论留到该部分,但“结果”中应该提及必要的解释,以便让读者能清楚地了解作者此次研究结果意义或重要性。(5) 文字表达应准确、简洁、清楚。避免使用冗长的词汇或句子来介绍或解释图表。为简洁、清楚起见,不要把图表的序号作为段落的主题句,应在句子中指出图表所揭示的结论,并把图表的序号放入括号中。例如“Figure 1 shows the relationship between A and B”不如“A was Significantly higher than B at all time points hecked (Figure 1)”.又如,“It is clearly shown in Table 1 that nocillin inhibited the growth of N. gonorrhoeae.”不发“Nocillin inhibited the growth of N. gonorrhoeae (Table 1).”
5.2 时态的运用 (1) 即指出结果在哪些图表中列出,常用一般现在时。如:Figure 2 shows the variation in the temperature of the samples over time. (2) 叙述或总结研究结果的内容为关于过去的事实,所以通常采用过去时。如:After flights of less than two hours, 11% of the army pilots and 33% of the civilian pilots reported back pain. (3) 对研究结果进行说明或由其得出一般性推论时,多用现在时。如:The higher incidence of back pain in civilian pilots may be due to their greater accumulated flying time.(4) 不同结果之间或实验数据与理论模型之间进行比较时,多采一般现在时(这种比较关系多为不受时间影响的逻辑上的事实)。如:These results agree well with the findings of Smith, et al.
camellia1014
第2楼2006/02/17
6 讨论
6.1 基本内 “讨论”的重点在于对研究结果的解释和推断,并说明作者的结果是否支持或反对某种观点、是否提出了新的问题或观点等。因此撰写讨论时要避免含蓄,尽量做到直接、明确,以便审稿人和读者了解论文为什么值得引起重视。讨论的内容主要有:(1) 回顾研究的主要目的或假设,并探讨所得到的结果是否符合原来的期望?如果没有的话,为什么?(2) 概述最重要的结果,并指出其是否能支持先前的假设以及是否与其他学者的结果相互一致;如果不是的话,为什么? (3) 对结果提出说明、解释或猜测;根据这些结果,能得出何种结论或推论?(4) 指出研究的限制以及这些限制对研究结果的影响;并建议进一步的研究题目或方向;(5) 指出结果的理论意义(支持或反驳相关领域中现有的理论、对现有理论的修正)和实际应用。
6.2 写作要点 (1) 对结果的解释要重点突出,简洁、清楚。为有效地回答研究问题,可适当简要地回顾研究目的并概括主要结果,但不能简单地罗列结果,因为这种结果的概括是为讨论服务的。(2) 推论要符合逻辑,避免实验数据不足以支持的观点和结论。根据结果进行推理时要适度,论证时一定要注意结论和推论的逻辑性。在探讨实验结果或观察事实的相互关系和科学意义时,无需得出试图去解释一切的巨大结论。如果把数据外推到一个更大的、不恰当的结论,不仅无益于提高作者的科学贡献,甚至现有数据所支持的结论也受到怀疑。 (3) 观点或结论的表述要清楚、明确。尽可能清楚地指出作者的观点或结论,并解释其支持还是反对早先的工作。结束讨论时,避免使用诸如“Future studies are needed.”之类苍白无力的句子。(4) 对结果科学意义和实际应用效果的表达要实事求是,适当留有余地。避免使用“For the first time”等类似的优先权声明。在讨论中应选择适当的词汇来区分推测与事实。例如,可选用“prove”,“demonstrate”等表示作者坚信观点的真实性;选用“show”,“indicate”,“found”等表示作者对问题的答案有某些不确定性;选用“imply”,“suggest”等表示推测;或者选用情态动词“can”,“will”, “should”,“probably”,“may”,“could”,“possibly”等来表示论点的确定性程度。
6.3 时态的运用 (1) 回顾研究目的时,通常使用过去时。如:In this study, the effects of two different learning methods were investigated. (2) 如果作者认为所概述结果的有效性只是针对本次特定的研究,需用过去时;相反,如果具有普遍的意义,则用现在时。如: In the first series of trials, the experimental values were all lower than the theoretical predictions. The experimental and theoretical values for the yields agree well. (3) 阐述由结果得出的推论时,通常使用现在时。使用现在时的理由作者得出的是具普遍有效的结论或推论(而不只是在讨论自己的研究结果),并且结果与结论或推论之间的逻辑关系为不受时间影响的事实。如:The data reported here suggest (These findings support the hypothesis, Our data provide evidence) that the reaction rate may be determined by the amount
of oxygen available.
7 结论 通常情况下,有关结论的内容都包括在“结果与讨论”或“讨论”中,但有时也可将“结论”单独列为一节。在“结论”中作者应清楚、简洁地叙述自己研究的主要认识或论点,其中包括最重要的结果、结果的重要蕴含、对结果的说明或认识等。应注意的是,撰写结论时不应涉及前文不曾指出的新事实,也不能在结论中重复论文中其他章节中的句子,或者叙述其他不重要或与自己研究没有密切联系的内容,以故意把结论拉长。(任胜利, 100085, 北京双清路83号国家自然科学基金委员会科学基金杂志部. rensl@mail.nsfc.gov.cn)
