celan
第1楼2006/03/02
A Guide to Identifying Common
Inorganic Fillers and Activators
Using Vibrational Spectroscopy
http://www.ijvs.com/volume2/edition3/section3.html
Abstract
Vibrational spectroscopy, (FT-IR and FT-Raman spectroscopy) has been used to study a range of inorganic fillers and activators. The paper demonstrates the information available from vibrational spectroscopy and suggests areas in which useful data can be gained.
Three specific examples of the use of FT-Raman spectroscopy in identifying fillers in some elastomeric products are included, as are peak positions (IR and Raman) used to identify the materials present.
lee214
第10楼2007/01/23
不见可以下载的图
