即将更新的标准生效日期:
标准名称 | 生效日 | 被取代的旧标准 |
EN 50364: 2010 Limitation of human exposure to electromagnetic fields from devices operating in the frequency range 0 Hz to 10 GHz, used in Electronic Article Surveillance (EAS), Radio Frequency Identification (RFID) and similar applications | 2012年11月1日 | EN 50364: 2001 |
EN 55022: 2006/A1: 2007 Information technology equipment - Radio disturbance characteristics - Limits and methods of measurement | 2011年10月1日 | EN 55022: 2006 |
EN 60065: 2002/A2: 2010 Audio, video and similar electronic apparatus - Safety requirements | 2013年10月1日 | EN 60065: 2002/A11: 2008 |
EN 60950-1: 2006/A1: 2010 Information technology equipment - Safety - Part 1: General requirements | 2013年3月1日 | EN 60950-1: 2006/A11: 2009 |
EN 61000-3-2: 2006/A1: 2009 EN 61000-3-2: 2006/A2: 2009 Electromagnetic compatibility (EMC) - Part 3-2: Limits — Limits for harmonic current emissions (equipment input current ≤16 A per phase) | 2012年7月1日 | EN 61000-3-2: 2006 |
EN 61000-3-3: 2008 Limits - Limitation of voltage changes, voltage fluctuations and flicker in public low-voltage supply systems, for equipment with rated current ≤16 A per phase and not subject to conditional connection | 2011年9月1日 | EN 61000-3-3: 1995 and its amendments |
EN 300 220-2 V2.3.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Short Range Devices (SRD); Radio equipment to be used in the 25 MHz to 1 000 MHz frequency range with power levels ranging up to 500 mW; Part 2: Harmonized EN covering essential requirements under article 3.2 of the R&TTE Directive | 2013年5月31日 | EN 300 220-2 V2.1.2 |
EN 300 330-2 V1.5.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Short Range Devices (SRD); Radio equipment in the frequency range 9 kHz to 25 MHz and inductive loop systems in the frequency range 9 kHz to 30 MHz; Part 2: Harmonized EN covering the essential requirements of article 3.2 of the R&TTE Directive | 2011年11月30日 | EN 300 330-2 V1.3.1 |
EN 300 440-2 V1.4.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Short range devices; Radio equipment to be used in the 1 GHz to 40 GHz frequency range; Part 2: Harmonized EN covering the essential requirements of article 3.2 of the R&TTE Directive | 2012年5月31日 | EN 300 440-2 V1.3.1 |
EN 301 406 V2.1.1 Digital Enhanced Cordless Telecommunications (DECT); Harmonized EN for Digital Enhanced Cordless Telecommunications (DECT) covering the essential requirements under article 3.2 of the R&TTE Directive; Generic radio | 2011年4月30日 | EN 301 406 V1.5.1 |
EN 301 489-1 V1.8.1 Electromagnetic compatibility and Radio Spectrum Matters (ERM); ElectroMagnetic Compatibility (EMC) standard for radio equipment and services; Part 1: Common technical requirements | 2011年10月1日 | EN 301 489-1 V1.6.1 |
EN 301 489-17 V2.1.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); ElectroMagnetic Compatibility (EMC) standard for radio equipment; Part 17: Specific conditions for Broadband Data Transmission Systems | 2011年10月1日 | EN 301 489-17 V1.3.2 |
EN 301 489-23 V1.4.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); ElectroMagnetic Compatibility (EMC) standard for radio equipment and services; Part 23: Specific conditions for IMT-2000 CDMA, Direct Spread (UTRA and E-UTRA) Base Station (BS) radio, repeater and ancillary equipment | 2012年6月30日 | EN 301 489-23 V1.3.1 |
EN 301 489-24 V1.5.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); ElectroMagnetic Compatibility (EMC) standard for radio equipment and services; Part 24: Specific conditions for IMT-2000 CDMA Direct Spread (UTRA and E-UTRA) for Mobile and portable (UE) radio and ancillary equipment | 2012年7月31日 | EN 301 489-24 V1.4.1 |
EN 301-489-4 V1.4.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); ElectroMagnetic Compatibility (EMC) standard for radio equipment and services; Part 4: Specific conditions for fixed radio links, Broadband Data Transmission System Base stations, ancillary equipment and services | 2011年1月31日 | EN 301 489-4 V1.3.1 |
EN 301 502 V9.2.1 Global System for Mobile communications (GSM); Harmonized EN for Base Station Equipment covering the essential requirements of article 3.2 of the R&TTE Directive | 2012年7月31日 | EN 301 502 V8.1.2 |
去年冬天
第1楼2011/11/30
EN 301 908-1 V4.2.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Base Stations (BS), Repeaters and User Equipment (UE) for IMT- 2000 Third-Generation cellular networks; Part 1: Harmonized EN for IMT-2000, introduction and common requirements, covering essential requirements of article 3.2 of the R&TTE Directive | 2011年11月30日 | EN 301 908-1 V3.2.1 |
EN 301 908-2 V4.2.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Base Stations (BS), Repeaters and User Equipment (UE) for IMT- 2000 Third-Generation cellular networks; Part 2: Harmonized EN for IMT-2000, CDMA Direct Spread (UTRA FDD) (UE) covering essential requirements of article 3.2 of the R&TTE Directive | 2011年11月30日 | EN 301 908-2 V3.2.1 |
EN 301 908-3 V4.2.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Base Stations (BS), Repeaters and User Equipment (UE) for IMT- 2000 Third-Generation cellular networks; Part 3: Harmonized EN for IMT-2000, CDMA Direct Spread (UTRA FDD) (BS) covering essential requirements of article 3.2 of the R&TTE Directive | 2011年11月30日 | EN 301 908-3 V3.2.1 |
EN 302 065 V1.2.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Ultra WideBand (UWB) technologies for communication purposes; Harmonized EN covering the essential requirements of article 3.2 of the R&TTE Directive | 2012年6月30日 | EN 302 065 V1.1.1 |
EN 302 208-2 V1.3.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Radio Frequency Identification Equipment operating in the band 865 MHz to 868 MHz with power levels up to 2 W; Part 2: Harmonized EN covering essential requirements of article 3.2 of the R&TTE Directive | 2011年11月30日 | EN 302 208-2 V1.2.1 |
