tutm
第1楼2011/12/27
有啊,耐驰STA449F3肯定可配
他们的网站是这么叙述的
The automatic sample changer is designed for routine measurements. It works day and night, giving you time for other tasks, and provides for optimal use of the STA 449 F3 Jupiter® (e.g. calibrations on the weekend).
A carousel is available for up to 20 sample and reference crucibles which can be automatically run in any order. The controlled generation of the required gas atmosphere in the sample chamber and cooling are automatic.
Of course, each sample can be assigned an individual measurement and evaluation macro. Easy-to-understand input masks lead you through the programming of the measurement series. And it is always possible to insert unplanned analyses into a preprogrammed series of measurements that is already in progress.
