kylabs
第7楼2012/02/28
是的,还可以用Cogent Diamond Hydride亲水柱试试,也是用来分离极性物质的。
海产品中的软骨藻酸Domoic acid LCMS检测。
Method Conditions
Column | Cogent Diamond Hydride™, 4µm, 100A | ||||||||||||
Catalog No. | 70000-15P-2 | ||||||||||||
Dimensions | 2.1 x 150 mm | ||||||||||||
Solvents |
Gradient |
Post Time | 5 min | ||||||||||||
Injection Vol. | 1 microL | ||||||||||||
Flow rate | 0.4 mL/min. | ||||||||||||
Detection | ESI - POS - Agilent 6210 MSD TOF MS | ||||||||||||
Samples | Samples from Dr. R.Kudela, Univ. of Calif., Santa Cruz, Dept. of Marine Sciences. Samples were injected as received. | ||||||||||||
Peak | Domoic acid 312.1442 m/z (M+H)+ | ||||||||||||
t0 | 0.9 min |
sepujiance
第8楼2012/03/12
Solvents |
Gradient |
t0 | 0.9 min |
