Camel
第2楼2012/03/15
EN 1186-1里有对各种测试方法使用的面积体积比有介绍
9.2 Surface to volume ratio
Where the surface to volume ratio to be used in contact with food is known this is used in the migration testing.
9.3 by total immersion
The surface to volume ratio in the total immersion test is conventionally 1 dm² of food contact area to 100 ml of food simulant.
9.4 Single surface testing using a cell
As an example the use of cell type A is described in EN 1186-4. The surface to volume ratio in the type A cell is conventionally 2,5 d m² of food contact area to 125 ml of food simulant.
9.5 Single surface testing by pouch
9.6 Single surface testing using a reverse pouch
Where the surface to volume ratio to be used in contact with food is not known, the conventional conditions are used, i.e. 2 dm² of
surface in contact with 100 ml of simulant.
