external locking mode 是什么意思???
  • xiaodaiban
    2012/03/15
核磁共振技术(NMR)
  • Spectra were measured with the external locking mode at various temperatures. chemical shifts were determined on an expanded scale (18 ppm per full scale) with the precision of 0.10 ppm.
    这里的 external locking mode和an expanded scale (18 ppm per full scale)都是什么意思啊?
  • sslin
    第1楼2012/03/28
    expanded scale 比较好理解. 就是平常只检测 15 ppm 左右, 现在扩展检测了 18 ppm 的范围.
    external locking mode 应该是指外锁法. 听说过, 没有实际操作过.
