去德国的silicone要求测7种organotin
  • gsmcpaulxu
    2012/03/28
食品接触材料
  •    很多实验室做有关silicone的测试时都会要求测7种organotin,而且要求不得检出,我查了下论坛上的帖子,很多都提到是出自于BFR的要求,可我查到BFR里只有Di-n-octyl-tin-dimaleinate和Di-n-octyl-tin-dilaurate的要求,也不是不得检出,不知道大家是否知道测7种organotin的要求是出自哪里的呢?谢谢
  • junmyliu
    第1楼2012/03/28
    去德国的与食品接触的硅胶没有要求有机锡测试
    只有法国 其食品接触硅胶是要求organotin测试的
    但也指明了只要做锡的迁移测试就可以了(Organotin:specific migration of tin must be less than 0.1milligram per kilogram of food,beverages and food products.)
    原文请看附件
    所以7种有机锡测试是没有依据的,当然测了总比没有测好。
  • zhi2688
    第2楼2012/04/01
    BFR I 里面有说道有机锡化合物,BfR XV里面的III 硅橡胶方面,有句话说到高分子聚合物要遵循BfR I 里面的指令。估计就是出自这里的了。
  • junmyliu
    第3楼2012/04/02
    板油指的“BfR XV里面的III 硅橡胶方面,有句话说到高分子聚合物要遵循BfR I 里面的指令。”,是不是下面一段中红色的这句:
    III. Silicone elastomers (Silicone rubber)
    1. The following starting materials may be used:
    Polymers complying with Section I, No.1 of this Recommendation
    Organopolysiloxanes with vinyl groups attached to the silicon atom
    Addition products of trivinylcyclohexane and a,w-dihydrogen-polyhydrogenmethyldimethyl-
    siloxanes, max. 10 %
    1-Dodecene, max. 20 %
    Polydimethyl- siloxanes and –silicones, 3-aminopropyl-group terminated, polymers with 1-
    isocyanato-3-isocyanatomethyl-3,5,5-trimethylcyclohexane10
    Polydimethyl- siloxanes and -silicones, 3-aminopropyl-group terminated, polymers with
    bis(4-isocyanatocyclohexyl)methane11
    这句应该指本建议(BfR XV)的第一节 第一段,如下:
    I. Silicone oils1
    a) Linear or branched and/or cyclic2 organopolysiloxanes with methyl groups alone or with
    n-alkyl(C2-C32), phenyl2 and/or hydroxyl groups attached to the silicon atom, and their
    condensation products with polyethylene and/or polypropyleneglykol.
    b) Linear or branched organopolysiloxanes as mentioned under a) but in addition with up
    to max. 5 % hydrogen and/or alkoxy(C2-C4) and/or carboalkoxyalkyl (-(CH2)2-17-C(O)-O-
    (CH2)0-17CH3)- and/or hydroxyalkyl(C1-C3) groups attached to the silicon atom.
    而BfR I 里虽然有有机锡的描述,但是在a)里面,不存在什么section I No.1,况且也没有限量,如下:
    This is an unofficial translation. Only the German version is binding.
    I. High Polymers Containing Plasticizers
    As of 01.06.2009
    To the extent that they are included in it, substances added as plasticizers to high polymers
    used in the production of commodities (articles, materials), made of plastic, in the sense of § 2,
    Para. 6, No. 1 of the Food and Feed Code (Lebensmittel- und Futtermittelgesetzbuch) must
    comply with the requirements of the Commodities Regulation (Bedarfsgegenständeverordnung).
    In addition, the use of plasticizers in such commodities is restricted to the following:
    Di-2-ethylhexyl terephthalate
    The following notes must be complied with:
    a) Organic tin stabilizers (e.g. di-n-octyl tin compounds, butylthiostannoic acid) may not be
    added because of their high tendency to migrate from plasticized PVC.
    b) Especially concerning the contact with foodstuffs belonging to the follwing groups great care
    has to be bestowed on compliance with the specific migration limits:
    - Foodstuffs in powder and fine-grain form (max. 3 mm in diameter)
    - Fatty foodstuffs containing fat in such a form that it would come into direct contact with
    films, coatings or tubes
    - Waxed or paraffin-coated foodstuffs
    - Milk and dairy products, including cheese
    - Foodstuffs which contain alcohol or essential oils
    c) Films which are specially made for packaging fresh meat have to be labelled with the following
    note:
    "Only for the packaging of fresh meat"
    This text has to be placed clearly visible and readable on the packaging of the film, the core on
    which the film is rolled and in the accompanying goods delivery documents.
    This is necessary to avoid the packaging of other foodstuffs by mistake. Because of techical
    reasons this label can not be placed on the film.
    就德国人的严谨 不会这样不对应。
    所以BfR XV根本没有提有机锡的迁移测试。
    zhi2688(zhi2688) 发表:BFR I 里面有说道有机锡化合物,BfR XV里面的III 硅橡胶方面,有句话说到高分子聚合物要遵循BfR I 里面的指令。估计就是出自这里的了。
