Abstract: The electric energy management and electric power monitoring system based on Profibus-DP were designed. The system structure and implementation principle were expounded. The implementation method of communication between main station and serial electric power meter slave station was given, and the key problems in main and slave station communication characteristics and feasibility. Key words: Profibus; PLC; bus bridge; network gateway; electric power monitoring meter; industrial communication
