求助paper review
  • chenyi6970
    2012/05/23
X射线衍射仪(XRD)
  • Indeed, since your XRD experiment is not a theta-two theta experiment but a detector scan (with a fixed grazing incidence angle), you are not able to measure any texture except if the diffraction vector stands along the texture direction which is roughly your case, by chance. I have calculated that the angle between the diffraction vector direction for the (002) diffraction peak and the normal of the sample surface is around 14° (assuming a 3° grazing angle).
    有高手给解释一下那个14度是怎么计算的吗?或者给点提醒,谢谢阿,跪谢
  • 小莫
    第1楼2012/05/23
    这个问题...同问
    衍射矢量不是与衍射面(002)的法线方向平行么,于是然后怎么算?
    对于入射角固定的衍射模式,我还真没接触过。
  • 小莫
    第2楼2012/05/25
    楼主能给讲讲为什么使用detector scan mode吗?
  • chenyi6970
    第3楼2012/05/25
    因为学校只有这个,呵呵
