MATTEL 已要求开展EN71-3新标准测试了?
  • 依风1986
    2012/06/30
ICP光谱
  • MATTEL 已要求VENDOR LABORATORY 和 Approved Supplier Chemical Lab展EN71-3新标准测试了。见邮件
    To Mattel Approved Vendor Chemical Lab and Approved Supplier Chemical Lab
    To implement EN71-3, the New Heavy Element Test requirement, this is the second step.
    We formally inform you, from June 27, 2012, the Heavy element test, the total content, please start to use the ICP-OES to run all the test sample solution to do the screening. About the draft new Heavy Element requirement and set up for the ICP-OES and calibration point, please refer to the attached file.
    Heavy element test, soluble content, after the total content screening test, if the total content is found exceed the soluble method one and / or exceed the soluble method two requirement, please also do the related soluble method one and/ or soluble method two test.
    Heavy Element Test report, Mattel QSOP 3600, QSOP 3602 requirement, the new test report will also include all the 17 Heavy Element total contents and soluble method one and / or soluble method two content when in need.
    Heavy Element test conclusion, please still use the QSOP 3600 Rev. W and QSOP 3602 Rev. E to draw the test conclusion until we have the further notification.
    If you have special case or any questions, please contact us.
    Best Regards
    Bruse Liu (MAPS Shenzhen PI Lab)
    看附件具体要求,请问版面有做MATTEL产品的工厂,公证行朋友如何应付的?
附件:
  • Fe
    第1楼2012/07/01
    过渡期快到了,很多机构都开始做了。
  • 第3楼2012/07/02
    还是那个样,ICP-OES可以测试大部分元素了。
  • 依风1986
    第4楼2012/07/02
    是的
    其实MATTEL对总含量加了NI,限定值高啊!
    可溶性的话就是Cd,变成17PPM,呵呵,其他都正常,新增加的我看ICP-OES都满足!只是工作量增加了,大家都做这些时候可以讨论下,小到标液共存,大到元素谱图分析,都可以讨论,我就先在这里抛砖引玉了
  • 依风1986
    第5楼2012/07/02
    先感谢大家对话题感兴趣,有更多做MATTEL玩具的朋友可以讨论下!谢谢大家
  • 月夜之痕
    第6楼2012/07/03
    附件下载完怎么打不开!
  • 依风1986
    第7楼2012/07/03
    重新传份看看,做MATTEL玩具的朋友可以看看
  • 月夜之痕
    第8楼2012/07/04
    0.005 mg/l, 0.05 mg/l, 0.1 mg/l for Cr soluble matrix test;
    0.005 都低于检出限了吧 这条线用ICP还能做准了吗
  • 依风1986
    第9楼2012/07/07
    MAttel 就是这样硬性规定的,你说你能怎么样?
  • frank_lee1981
    第10楼2012/07/08
    good inf. thanks for share!!!
    Please share the QSOP 3600 and 3602 lastest version. thanks for god
