vic
第5楼2012/07/03
Article 12
Overall migration limit
1.
Plastic materials and articles shall not transfer their constituents to food simulants in quantities exceeding 10 milligrams oftotal constituents released per dm2 of food contact surface(mg/dm2).
2.
By derogation from paragraph 1, plastic materials andarticles intended to be brought into contact with food intendedfor infants and young children, as defined by Commission Directives 2006/141/EC(1)
OJ L 401, 30.12.2006, p. 1. and 2006/125/EC(2)
OJ L 339, 6.12.2006, p. 16., shall not transfertheir constituents to food simulants in quantities exceeding60 milligrams of total of constituents released per kg of foodsimulant.
Article 17
Expression of migration test results
4.For caps, gaskets, stoppers and similar sealing articles theoverall migration value shall be expressed in:
(a)
mg/dm2 applying the total contact surface of sealing articleand sealed container if the intended use of the article isknown;
(b)
mg/article if the intended use of the article is unknown.
