qq250083771
第1楼2012/09/10
81.2 HPLC法同时测定养血化瘀合剂中阿魏酸和甘草酸的含量
【作者】 张翔; 韩继永;
【Author】 Zhang Xiang~1,Han Jiyong~2(1.Nanjing Institute for Drug Control,Nanjing 210015,China;2.Nanjing Haiguang Institute of Applied Chemistry)
【机构】 南京市药品检验所; 南京海光应用化学研究所;
【摘要】 目的:建立HPLC法同时测定养血化瘀合剂中阿魏酸、甘草酸含量的方法。方法:采用Diamonsil C18(200 mm×4.6mm,5μm)色谱柱,以乙腈为流动相A,0.085%磷酸水溶液为流动相B,进行线性梯度洗脱,流速为1.0 ml·min-1,检测波长为245 nm,柱温为25℃。结果:阿魏酸在5.02~50.24μg·ml-1(r=0.9.99 9)和甘草酸在2.46~24.62μg·ml-1(r=0.999 9)的范围内浓度与峰面积呈良好的线性关系,阿魏酸和甘草酸的加样回收率分别为100.1%(n=9,RSD=1.57%)和99.8%(n=9,RSD=0.98%)。结论:本法操作简单、快速、重复性好,结果准确可靠,可用于养血化瘀合剂的质量控制。 更多还原
【Abstract】 Objective:To establish an HPLC method for the simultaneous determination of ferulic acid and glycyrrhizic acid in yangxuehuayu mixture.Method:The Diamonsil C18(200 mm×4.6 mm,5μm) column was used.The mobile phase was acetonitrile and 0.085%phosphoric acid with gradient elution.The flow rate was 1 ml·min-1.The wavelength was 245 nm.The temperature of column was 25℃·.Result:The linear ranges of ferulic acid and glycyrrhizic acid were 5.02-50.24μg·ml-1(r = 0.999 9) a... 更多还原
【关键词】 养血化瘀合剂; 阿魏酸; 甘草酸; 高效液相色谱法;
【Key words】 Yangxuehuayu mixture; Ferulic acid; Glycyrrhizic acid; HPLC;
qq250083771
第3楼2012/09/10
81.4 HPLC法测定夏天无注射液中原阿片碱的含量
【作者】 周利贤;
【Author】 Zhou Lixian(Nantong Institute for Drug Control,Jiangsu Nantong 226006,China)
【机构】 南通药品检验所;
【摘要】 目的:建立用高效液相色谱法测定夏天无注射液中原阿片碱含量的方法。方法:采用Diamonsil C18(150 mm×4.6mm,5μm)色谱柱,柱温:30℃,进样量:10μl,以乙腈-三乙胺醋酸液(18:82)为流动相,流速:1.0 ml·min-1,检测波长:290nm。结果:原阿片碱在17.62~88.10μg·ml-1范围内,浓度与峰面积呈良好的线性关系(r=0.999 9)。平均回收率为99.8%,RSD=0.8%。结论:本法准确可靠,可用于夏天无注射液中原阿片碱的含量测定。 更多还原
【Abstract】 Objective:To establish an HPLC method for determination of content of protopine in rhizoma corydalis decumbentis injection. Method:The HPLC with Diamonsil C18(150 mm×4.6 mm,5μm) column was used,the column temperature was at 30℃, and the injection volume was 10μl,a mixture of acetonitrile-triethylamine acetic acid solution(18:82) was used as mobile phase,the flow rate was 1.0 ml·min-1,and detection wavelength was 290 nm.Result:The linear rang of protopine was 17.62-88.10μg·m... 更多还原
【关键词】 夏天无注射液; 原阿片碱; 含量测定; 高效液相色谱法;
【Key words】 Rhizoma Corydalis Decumbentis injection; Protopine; Content determination; HPLC;
qq250083771
第4楼2012/09/10
81.5 HPLC法测定葶苈降血脂颗粒中黄芩苷的含量
【作者】 王德满; 王学峰; 丁铁丽;
【Author】 Wang Deman(Anshan Recovery Hospital,Liaoning Anshan 114011,China);Wang Xuefeng(Anshan Tiexi Hospital);Ding Tieli(Defeng Pharmaceutical Industry Limited Company,Liaoning Conscience Group)
【机构】 鞍山市精神康复医院; 鞍山铁西医院; 辽宁良心集团德峰药业有限公司;
【摘要】 目的:建立高效液相色谱法测定葶苈降血脂颗粒中黄芩苷含量质量控制标准。方法:色谱柱:Diamonsil C18柱(150mm×4.6mm,5μm);流动相:甲醇-水-磷酸(47:53:0.2);流速:1.0ml·min-1;检测波长:278nm;柱温:室温。结果:黄芩苷在0.075~0.377μg·ml-1范围内线性关系良好(r=0.999 8),平均回收率为98.71%、RSD=1.73%(n=5)。结论:HPLC法简便、灵敏准确、重复性好、结果可靠,可作为葶苈降血脂颗粒的质量控制标准。 更多还原
【Abstract】 Objective:To establish an HPLC method for determination of bailalin in tingli granules.Method:The Diamonsil C18 column(150mm×4.6mm,5μm)was used.The mobile phase was methanol:water:phosphoric acid(47:53:0.2),The flow rate was 1ml·min-1,the detection wavelength was 278nm and the column themperature was room temperature.Result:The linear range was 0.075-0.377μg(r=0.999 8).The average recovery was 98.71%,RSD=1.73%(n=5).Conclusion:This method is simple and credible.It can be use... 更多还原
【关键词】 葶苈降血脂颗粒; 高效液相色谱法; 黄芩苷;
【Key words】 Tingli hypolipidemic granules; HPLC; Bailalin;
qq250083771
第5楼2012/09/10
81.6 RP-HPLC法测定战创伤涂膜剂中3组分的含量
【作者】 戴卫红; 李云霞; 刘建芳; 张素芬; 侯艳宁;
【Author】 Dai Weihong,Li Yunxia,Liu Jianfang,Zhang Sufen,Hou Yanning(Bethune International Peace Hospital,Shijiazhuang 050082,China)
【机构】 解放军白求恩国际和平医院;
【摘要】 目的:建立高效液相色谱法测定战创伤涂膜剂中替硝唑、盐酸达克罗宁和醋酸氯己定3组分的含量。方法:色谱柱为Diamonsil C18(150 mm×4.6 mm,5μm);流动相:甲醇-0.02 mol·L-1磷酸二氢钾水溶液(含三乙胺0.4%,用磷酸调节pH至2.5)(50:50);流速:1.0 ml·min-1;检测波长分别为317 nm,280 nm,261 nm;柱温:25℃。结果:替硝唑、盐酸达克罗宁和醋酸氯己定的线性范围分别为1.02~10.20,12.48~124.80和5.42~54.20μg·ml-1,相关系数均为1.0000;平均回收率分别为101.6%、100.1%和102.3%。结论:本法简便准确,重复性好,可用于战创伤涂膜剂的质量控制。 更多还原
【Abstract】 Objective:To establish an HPLC method for the determination of tinidazol,dyclonine hydrochloridum and chlorhexidine acetate in film forming solution for war wound and trauma.Method:The HPLC separation was conducted on a Diamonsil C18 column (150 mm×4.6 mm,5μm),the mobile phase consisted of methanol and 0.02 mol·L-1 potassium dihydrogen phosphate solution (contained 0.4%triethylamine,and adjust pH to 2.5 with phosphoric acid)(50:50),the flow rate was 1.0 ml·min-1,... 更多还原
【关键词】 高效液相色谱法; 涂膜剂; 替硝唑; 盐酸达克罗宁; 醋酸氯己定;
【Key words】 HPLC; Film forming solution; Tinidazol; Dyclonine hydrochloridum; Chlorhexidine acetate;
【基金】 全军十一五科技攻关课题(06G024)
qq250083771
第6楼2012/09/10
81.7 HPLC法测定保儿安颗粒中熊果酸的含量
【作者】 张立峰; 刘灿仿;
【Author】 Zhang Lifeng,Liu Canfang(Department of Pharmacy,Xingtai Medical College,Hebei Xingtai 054000,China)
【机构】 邢台医学高等专科学校药剂教研室;
【摘要】 目的:建立高效液相色谱法测定保儿安颗粒中熊果酸的含量。方法:采用Diamonsil ODS C18(250 mm×4.6mm,5μm)色谱柱;流动相为乙腈-甲醇-2%乙酸铵水溶液(65:10:25);检测波长为220 nm。结果:熊果酸进样量在1.59~7.96μg内与峰面积积分值呈良好的线性关系(r=0.999 9);平均加样回收率为99.6%(RSD=0.22%,n=6)。结论:方法简便、准确,可作为该制剂的质量控制方法。 更多还原
【Abstract】 Objective:To establish an HPLC method for the determination of ursolic acid in Bao’ er’ an granules.Method: The Diamonsil ODS C18(250 mm×4.6mm,5μm) column was used with the mobile phase consisted of acetonitrile-methanol - 2% ammonium acetate water solution(65:10:25).The detection wavelength was at 220 nm.Result:The linear range of ursolic acid was 1.59-7.96μg between the injection quantity and the peak area(r=0.999 9).The average recovery was 99.6%with the RSD of 0.22%(n =6).Conclusi... 更多还原
【关键词】 熊果酸; 保儿安颗粒; 高效液相色谱法;
【Key words】 Ursolic acid; Bao’er’an granules; HPLC;
qq250083771
第7楼2012/09/10
81.8 HPLC法测定藤黄健骨丸中松果菊苷的含量
【作者】 姜翔之; 陈英红; 罗浩铭; 姜瑞芝;
【Author】 Jiang Xiangzhi~1,Chen Yinghong~2,Luo Haoming~2,Jiang Ruizhi~2(1.Department of Pharmacy,Japan-China Union Hospital,Jilin University, Changchun 130051,China;2.Jilin Academy of Traditional Chinese Medicine and Material Medical Sciences)
【机构】 吉林大学中日联谊医院药剂科; 吉林省中医药科学院;
【摘要】 目的:建立藤黄健骨丸中松果菊苷含量的HPLC测定方法。方法:色谱柱:Diamonsil C18(250 mm×4.6mm,5μm),流动相:甲醇-0.1%甲酸(28.5:71.5),流速:1.0ml·min-1,柱温:25℃,检测波长:330nm。结果:松果菊苷线性范围为0.18~1.84μg,r=0.999 9,平均回收率为98.36%,RSD为0.56%(n=6)。结论:本法操作简便,结果准确。 更多还原
【Abstract】 Objective:To establish an HPLC method for the determination of echinacoside in Tenghuang Jiangu pills.Method:A Diamonsil C18(250 mm×4.6mm,5μm) was used.The mobile phase consisted of methanol -0.1%formic acid(28.5:71.5).The flow rate was 1.0ml?min-1 and the column temperature was 25℃.The content was detected at a wavelenght of 330nm.Result:The linear range was 0.18-1.84μg for echinacoside(r=0.9999).The average recovery rate was 98.36%with RSD of 0.56%(n=6). Conclusion:The me... 更多还原
【关键词】 藤黄健骨丸; 松果菊苷; 高效液相色谱法;
【Key words】 Tenghuang Jiangu pills; Echinacoside; HPLC;
qq250083771
第8楼2012/09/10
81.9 高效液相色谱法测定抗感解毒颗粒中葛根素含量
【作者】 田晓云; 徐欣昌; 崔金秀;
【机构】 枣庄矿业集团中心医院药剂科; 山东三九药业有限公司;
【摘要】 目的:建立高效液相色谱法测定抗感解毒颗粒中葛根素的含量。方法:采用Diamonsil-C18(250 mm×4.6 mm,5μm)色谱柱;甲醇-水(25:75)为流动相;柱温为30℃;流速为1.0 ml·min-1;检测波长为250nm。结果:葛根素进样量在0.0800~0.6420μg间呈良好的线形关系;平均加样回收率为99.6%(RSD=1.3%)。结论:本方法准确可行,可用于本品的质量控制。 更多还原
【关键词】 抗感解毒颗粒; 高效液相色谱法; 葛根素;
qq250083771
第9楼2012/09/10
81.10 HPLC法测定活血通脉片中橙皮苷的含
作者: 张红岩[1] 耿琍[1] 唐岩[1] 耿玮[2]
作者单位: 吉林省中医药科学院,长春,130021
吉林省食品药品检验所
期 刊: 中国药师
关键词: 活血通脉片 橙皮苷 高效液相色谱法
摘要:目的:建立活血通脉片中橙皮苷的HPLC测定方法.方法:采用Diamonsil-C18色谱柱(250mm×4.6mm,5μm),流动相为甲醇-水-冰醋酸(33:67:1);流速为1.0ml·min-1,检测波长为284 nm.结果:橙皮苷进样量在0.08~0.40μg范围内与峰面积线性关系良好,r=0.999 8,平均回收率为98.5%,RSD为0.8%(n=5).结论:方法可用于活血通脉片的质量控制.
