省部重点实验室
第1楼2012/09/14
参考答案
1.The following strains were courteously provided by or obtained from Dr. U. Miller (University of Minnesota).
2.The data of the analysis on cell cycle parameters have revealed that the cell cycle is advanced by factor X (Fig. 1).
3.After 2 hr, we ended the incubation of CO2 on a Ag(110) surface.
4.Homologous recombination is the preferred mechanism of DNA repair in yeast.
5.The effect of temperature on conductivity was found not to change dramatically. OR The effect of temperature on conductivity did not change dramatically.
6.Often, jewel weed grows Close to poison ivy.
7.Transduction efficiencies in vivo were much higher than those in vitro.
8.Upon heat activation, filament size increased, and the number of buds decreased. Both of these changes were only seen for cytokinin mutants.
9.Although transition metals can form bonds with six shared electron pairs, only quadruply bonded compounds can be isolated as stable species at room temperature.
10.After infecting a host cell, a herpes viral DNA genome enters the nucleus where it is transcribed to both messenger RNAs (mRNAs) and noncoding RNAs (ncRNAs).
