magabaya
第7楼2012/10/12
这个是全文,麻烦大侠告诉我,如何理解这段话?
We further studied the structures of these Cu nanowires by high-resolution TEM. Figure 2 shows TEM and the corresponding high-resolution TEM images taken from the middle and end portions of two different Cu nanowires, respectively. The insets schematically illustrate the orientations of the Cu nanowires relative to the incident electron beam (indicated by arrows). The high-resolution TEM images clearly show the existence of {111} twin planes parallel to the long axis of the nanowire. When the direction of the e-beam was perpendicular to the bottom side of the pentagonal nanowire (Figure 2 b), two sets of fringes with lattice spacing of 2.1 nm and 1.3 nm were observed, corresponding to the {111} and {220} planes of Cu, respectively. Figure 2 d shows the high-resolution TEM image taken from a Cu nanowire oriented with one of its side faces parallel to the e-beam. The fringes with lattice spacing of 2.1, 1.8, and 1.3 could beindexed to the {111}, {200}, and {220} planes of Cu, respec-tively. Based on the results of both SEM and high-resolution TEM analyses, we can conclude that the Cu nanowires had a penta-twinned structure bound by ten {111} facets at the two ends and five {100} side faces, which are consistent with the results previously reported for other metals including Ag, Au,
and Pd. [21]
