qq250083771
第1楼2012/10/30
146.2 HPLC法测定氧氟沙星滴耳液中氧氟沙星的含量
【作者】 王彦厚; 贾雷;
【Author】 WANG Yan-hou1,JIA Lei2(1.Zibo Institute for Drug Control of Shandong Province,Zibo 255086,China;2.Zibo Science and Technology Vocational College of Shandong Province,Zibo 255314,China)
【机构】 淄博市药品检验所; 淄博科技职业学院药学系;
【摘要】 目的建立测定氧氟沙星滴耳液中氧氟沙星含量的HPLC方法。方法采用Dikma Diamonsil C18柱(4.6 mm×150 mm,5μm),乙腈-0.1%三乙胺溶液(14∶86,H3PO4调节pH值至3.0)为流动相,柱温35℃,流速1.0 mL/min,Waters 996 PDA检测器,检测波长294 nm。结果进样量在0.153 9~3.078 0μg范围内线性关系良好,r=0.999 9(n=6),平均回收率99.84%,RSD=0.56%。结论该方法准确、简便、重现性好,可用于氧氟沙星滴耳液的含量测定。 更多还原
【Abstract】 Objective To establish an HPLC method for determination of ofloxacin in ofloxacin otic solution.MethodsThe Dikma Diamonsil C18 stainless steel column(4.6 mm×150 mm,5 μm)was used,the flow rate was 1.0 mL/min with the acetonitrile-0.1% triethy solution(14∶86)(pH was adjusted to 3.0 with phosphoric acid)as mobile phase,the column temperature was 35 ℃,and the Waters 996 PDA detection set wavelength was at 294 nm.ResultsThere was good linearity of the calibration carve between 0.153 9~3.078 0 μg,r=0.... 更多还原
【关键词】 HPLC; 氧氟沙星滴耳液; 氧氟沙星;
【Key words】 HPLC; Ofloxacin otic solution; Ofloxacin;
qq250083771
第2楼2012/10/30
146.3 HPLC法测定当归龙荟片中阿魏酸的含量
【作者】 王进; 崔宇姣; 王艳玲;
【Author】 WANG Jin,CUI Yu-jiao,WANG Yan-ling(The Center Hospital of Benxi City,Benxi 117000,China)
【机构】 本溪市中心医院;
【摘要】 目的建立测定当归龙荟片中阿魏酸含量的HPLC方法。方法采用Diamonsil C18柱(200mm×4.6mm,5μm)分离,以甲醇:0.1%磷酸(体积比为120∶280)为流动相进行洗脱,流速为1.0mL/min,检测波长为316nm。结果阿魏酸的线性范围为0.3136~6.271mg/L(r=0.9995),方法的平均回收率分别为100.5%(RSD=1.0%)。结论本实验为当归龙荟片的质量控制提供了科学的方法。 更多还原
【Abstract】 Objective To establish a RP-HPLC method for determination of ferulid acid in Dangguilonghui Tablets.Methods The chromatography was carried out on a Diamonsil ODS column(200 mm × 4.6 mm,5 μm)with methanol-1%(φ)phosphate acid solution(120∶280,v/v)as the mobile phase at a flow rate of 1.0 mL /min.The detection wavelength was set at 316 nm.Results The calibration curve was linear within the range of 0.313 6~6.271 mg/L(r=0.999 5),the average recoveries was 100.5%(RSD=1.0%).Conclusion This method is a... 更多还原
【关键词】 高效液相色谱法; 当归龙荟片; 阿魏酸;
【Key words】 HPLC; Dangguilonghui Tablets; Ferulid acid;
qq250083771
第3楼2012/10/30
146.4 高效液相色谱法测定景天三七胶囊中没食子酸的含量
【作者】 王志刚; 黄岩; 杨洪武; 郭武;
【Author】 WANG Zhi-gang1,HUANG Yan2,YANG Hong-wu3,et al(1.Liaoning Province Pharmacy Industry Academe,Shenyang 110015,China;2.Liaoning Talsy Medicine Co.,Ltd,Shenyang 110001,China;3.Liaoning Tianfeng Industrial Sock Co.,Ltd,Shenyang 110027,China;4.Shenyang Baicao Medicine Co.,Ltd,Shenyang 110003,China)
【机构】 辽宁省医药工业研究院; 辽宁天士力医药有限公司; 辽宁天峰实业股份有限公司; 沈阳百草医药有限公司;
【摘要】 目的建立景天三七胶囊中没食子酸含量的测定方法。方法采用HPLC法,色谱柱为Dia-monsil C18(200 mm×4.6 mm,5μm),流动相为甲醇-0.6%磷酸溶液(12∶88),检测波长271 nm,流速1.0 mL/min,柱温40℃。结果没食子酸线性范围为160.1~800.5 ng(r=0.999 9);平均回收率为99.05%,RSD=0.88%(n=6)。结论所用方法简便、快速、准确。 更多还原
【Abstract】 Objective To establish a method for the determination of gallic acid in Jingtiansanqi capsules.Methods HPLC was used.The determination was performed on a Diamonsil C18(200 mm×4.6 mm,5 μm)column by UV detector at 271 nm with methanol-0.6% Phosphoric acid(12∶88) as the mobile phase.The flow rate was 1.0 mL/min with column temperature of 40 ℃.Results The calibration curve showed a good linearity within the range of 160.1~800.5 ng(r=0.999 9).The average recovery was 99.05% with RSD of 0.88%(n=6).Con... 更多还原
【关键词】 景天三七胶囊; 没食子酸; 高效液相色谱法;
【Key words】 Jingtiansanqi capsules; Gallic acid; HPLC;
qq250083771
第4楼2012/10/30
146.5 RP-HPLC法测定蒲公英中绿原酸与咖啡酸的含量
【作者】 宗东升; 沈忱; 李丹; 高晓霞; 赵云丽;
【Author】 ZONG Dong-sheng1,SHEN Chen2,LI Dan3,et al(1.Shenyang Pharmaceutical University,Shenyang 110016,China;2.Institute for Drug Control of Liaoyang City,Liaoyang 111000,China;3.Anshan Ju Li Da Pharmacy Co.,Ltd,Anshan 114000,China)
【机构】 沈阳药科大学; 辽阳市药品检验所; 鞍山市巨力大药房有限公司;
【摘要】 目的测定蒲公英中绿原酸与咖啡酸的含量。方法采用Diamonsil C18色谱柱,流动相为乙腈-磷酸二氢钠缓冲液(13∶87,v/v),检测波长323 nm。结果绿原酸在2.4~48.0μg/mL(r=0.999 5),咖啡酸在1.0~20.0μg/mL(r=0.999 7)线性关系良好,咖啡酸、绿原酸的平均回收率分别为99.7%(RSD=0.8%)和100.8%(RSD=1.1%)。结论该方法准确、可靠、重现性好,可作为控制蒲公英药材质量的方法。 更多还原
【Abstract】 Objective RP-HPLC method was established to determine chlorogenic acid and caffeic acid in Herba taraxaci.Methods Diamonsil C18 column was used with a mixture of acetonitrile and sodium phosphate buffer(13∶87,v/v) as mobile phase.Results The linear ranges were 2.4~48.0 μg/mL(r=0.999 5),1.0~20.0 μg/mL(r=0.999 7) respectively.The recoveries were 99.7%(RSD=0.8%),100.8%(RSD=1.1%) respectively.Conclusion The assay method is simple,rapid and with good reproducibility and,it could provide the quality a... 更多还原
【关键词】 蒲公英; 反相高效液相色谱法; 绿原酸; 咖啡酸;
【Key words】 Herba taraxaci; RP-HPLC; Chlorogenic acid; Caffeic acid;
qq250083771
第5楼2012/10/30
146.6 HPLC法测定海马多鞭丸中淫羊藿苷的含量
【作者】 侯峰; 王国旗; 田金苗;
【Author】 HOU Feng,WANG Guo-qi,TIAN Jin-miao(Liaoning Institute for Control of Food and Drug,Shenyang 110023,China)
【机构】 辽宁省食品药品检验所; 辽宁省医药经贸公司; 辽宁省食品药品检验所 沈阳110023; 沈阳110000; 沈阳110023;
【摘要】 目的建立HPLC法测定海马多鞭丸中淫羊藿苷含量的方法。方法色谱柱:Diamonsil C18(5μm,200 mm×4.6 mm),流动相:乙腈-水(30∶70),检测波长:270 nm。结果淫羊藿苷进样量在0.073~0.730μg范围内呈良好的线性关系。平均回收率99.89%,RSD为0.52%。结论该方法简便准确,重现性好,可作为海马多鞭丸质量控制的依据之一。 更多还原
【Abstract】 Objective To establish a method for determination of ecariine in Haimaduobian pill.Methods HPLC column C18(200 mm×4.6 mm,5 μm);mobile phase:acetonitrile-water(30∶70);detection wavelength:270 nm.Results A linear relationship of ecariine was good(0.073 0~0.730 μg,r=0.999 9).The average recovery was 99.89% with RSD=0.52%(n=6).Conclusion The method is simple,accurate,and it can be used for the quality control of Haimaduobian pill. 更多还原
【关键词】 海马多鞭丸; 淫羊藿苷; HPLC法;
【Key words】 Haimaduobian pill; Ecariine; HPLC;
qq250083771
第6楼2012/10/30
146.7 RP-HPLC法测定犬血浆中司他夫定的血药浓度
【作者】 王虹; 高淑华; 李发美;
【Author】 WANG Hong,GAO Shu-hua,LI Fa-mei(School of Pharmacy,Shenyang Pharmaceutical University,Shenyang 110016,China)
【机构】 沈阳药科大学药学院; 沈阳药科大学药学院 沈阳110016; 沈阳110016;
【摘要】 目的建立一种RP-HPLC方法测定犬血浆中司他夫定的浓度。方法血浆样品经碱化处理,再用有机相提取后吹干,残渣用流动相溶解进样分析。色谱柱:Diamonsil C18柱(150 mm×4.6 mm,5μm,ID),流动相:甲醇-水(20∶80),流速:1.0 mL/min,柱温:室温,检测波长:266 nm。以脱水胸苷为内标,测定了犬口服司他夫定口服溶液后的血药浓度-时间过程。结果标准曲线线性范围为0.02~5.0μg/mL,最低检测限为0.02μg/mL,回收率均>50%,日内、日间精密度RSD均<15%。结论此方法快速、可靠,可用于司他夫定血药浓度分析及药代动力学研究。 更多还原
【Abstract】 Objective To develop a RP-HPLC method for the determination of stavudine in the plasma of dogs.Methods Samples were treated with phosphate buffer(pH 6.0),and then were extracted by ethylester.The extract was injected into the HPLC system with an analytical column of Diamonsil C18(150 mm×4.6 mm,5 μm,ID) with the column temperature at room temperature.The mobile phase consisted of a mixture of water-methanol(80∶20,v/v) with a flow rate of 1.0 mL/min.The stavudine was detected by UV absorption at 2... 更多还原
【关键词】 司他夫定; RP-HPLC; 血药浓度; 含量测定;
【Key words】 Stavudine; RP-HPLC; Plasma concentration; Determination of content
qq250083771
第7楼2012/10/30
146.8 HPLC法测定硫普罗宁片释放度
【作者】 周志明; 何丽媛;
【Author】 ZHOU Zhi-ming,HE Li-yuan(1.Department of Pharmacy,The First Hospital of China Medical University,Shenyang 110001,China; 2.Shengjing Hospital of China Medical University,Shenyang 110004,China)
【机构】 中国医科大学附属第一医院药剂科; 中国医科大学附属盛京医院药剂科 沈阳110001; 沈阳110004;
【摘要】 目的采用高效液相色谱法测定硫普罗宁片释放度。方法采用高效液相色谱法。用Diamon-sil(r)C18色谱柱,以甲醇-水(5∶95)为流动相,用磷酸调pH值至2.5,流速为1.0mL/min,检测波长为205nm。结果本法的线性范围为10~100μg/mL,r=0.9999,平均回收率为100.4%,RSD为1.0%(n=9)。结论本法专属性强,结果准确可靠,可用于硫普罗宁片释放度的测定。 更多还原
【Abstract】 Objective To establish a HPLC method for the determination of the dissolution of Tiopronin tablet.Methods The dissolution of Tiopronin tablet was determinated by HPLC.Diamonsil(r) C18 column was used with methanol and water (5∶95) as mobile phase whose pH value was mediated to 2.5 by phosphoric acid,flow rate was 1.0 mL/min,the detecting wavelength was at 205 nm.Results The linear range was from 10 μg/mL to 100 μg/mL,r=0.999 9,the average recovery was 100.4%,RSD=1.0%(n=9).Conclusion This method ... 更多还原
【关键词】 硫普罗宁; 释放度; 高效液相色谱法;
【Key words】 Tiopronin; Dissolution; HPLC;
qq250083771
第8楼2012/10/30
146.9 HPLC法测定消渴胶囊中葛根素的含量
【作者】 王红鑫; 张锦红;
【Author】 WANG Hong-xin,ZHANG Jin-hong(Huludao Institute for Drug Control,Huludao 125000,China)
【机构】 葫芦岛市药品检验所; 葫芦岛市药品检验所 辽宁葫芦岛125000; 辽宁葫芦岛125000;
【摘要】 目的建立消渴胶囊中葛根素的含量测定方法。方法采用高效液相色谱法,色谱柱为Dia-monsil C18柱(5μm,4.6 mm×200 mm),乙腈-水(15∶85)为流动相,流速1.0 mL/min,检测波长为306 nm。结果在180.7~421.7μg/mL范围内线性关系良好(r=0.999 6),平均回收率100.6%,RSD为1.9%。结论本法快速简便,结果准确。 更多还原
【Abstract】 Objective To establish a method for the determination of puerarin in Xiaoke capsules.Methods HPLC was used.Column:DiamonsilC18(5 μm,4.6 mm×200 mm),mobile phase:acetonitrile-water(15∶85),flow rate:1.0 mL/min,wavelength:306 nm.Results The linear range was 180.7~421.7 μg/mL(r=0.999 6),the mean recovery was 100.6% and the RSD was 1.9%.Conclusion The method is rapid,simple and accurate. 更多还原
【关键词】 高效液相色谱法; 消渴胶囊; 葛根素;
【Key words】 HPLC; Xiaoke capsules; Puerarin;
qq250083771
第9楼2012/10/30
146.10 HPLC法测定大鼠血浆中黄芩苷的浓度
【作者】 邱枫; 徐静华; 肇丽梅; 何晓静;
【Author】 QIU Feng1,2,XU Jing-hua2,ZHAO Li-mei1,HE Xiao-jing(1.Department of Pharmacy,Shengjing Hospital of China Medical University,Shenyang 110004,China;2.Shenyang Pharmaceutical Universityy,Shenyang 110016)
【机构】 中国医科大学附属盛京医院药剂科; 沈阳药科大学;
【摘要】 目的建立测定大鼠血浆中黄芩苷浓度的HPLC方法。方法用甲醇-乙腈沉淀血浆蛋白,将上清液吹干后残渣再溶解后进行测定;色谱柱采用DiamonsilC18柱,以甲醇-0.2%磷酸(60:40,v/v)为流动相,流速为1.0mL/min,检测波长为280nm,选取卡马西平为内标物。结果黄芩苷在0.25~10.0μg/mL范围内呈良好线性关系(r=0.9990),日内、日间RSD均小于5%;平均相对回收率与平均提取回收率分别为98.4%和69.3%。结论该方法简单快速,适用于黄芩苷的血药浓度测定及药动学研究。 更多还原
【Abstract】 Objective A rapid sensitive HPLC method was developed to determine baicalin in the rat plasma.Methods The rat plasma was pretreated by precipitating with methanol-acetonitrile.Diamonsil C18 column was used.The mobile phase consisted of methanol-0.2% phosphoric acid(60:40,v/v).The flow rate was 1.0 mL/min,and the UV detection was set at 280 nm.CBZ was used as internal standard.Results The linear calibration curves were obtained in the concentration range of 0.25~10.0 μg/mL(r=0.999 0).The within-d... 更多还原
【关键词】 黄芩苷; HPLC; 血浆;
【Key words】 Baicalin; HPLC; Plasma;
