这种故障我们也发生过,对Plunger不能上升的问题,我们一方面对Plunger的上面倒酒精清洗除尘,另一方面调整Plunger的位置,对Turret超时,跳高压,我们请PANalytical工程师清光室和有关齿轮.我建议对你仪器搞一次彻底的维护,先清一下光室和电路板,实在不行打个报告请PANalytical工程师搞一次彻底的维护,不过收费很高
PKPHY 发表:PANalytical Error messages(MAGIX 2403)
1、跳高压问题:
(1)Plunger不能上升,
4502 5/25/2006 7:52:34 PM SuperQ Spectrometer warning: 7,5,55,0 X-Ray tube is off; 55.
4501 5/25/2006 7:52:07 PM SuperQ Spectrometer error: 3,0,2,0,0 Plunger up timeout.
(2)Turret超时,跳高压
4502 5/25/2006 12:50:53 PM SuperQ Spectrometer warning: 7,5,52,0 X-Ray tube is off; 52.
4514 5/25/2006 12:50:53 PM SuperQ Aftercare info: SpmSampleChn(iSpmCmdLoadSampleC): RSMH,
4501 5/25/2006 12:50:51 PM SuperQ Spectrometer error: 3,0,4,0,0 Turret timeout.
(3)试样做完时,盖子未打开,泄真空,跳高压
4502 5/25/2006 8:52:35 AM SuperQ Spectrometer warning: 7,5,53,0 X-Ray tube is off; 53.
4514 5/25/2006 8:52:35 AM SuperQ Aftercare info: SpmSampleChn(iSpmCmdTurnTurretC): Ready,
4501 5/25/2006 8:52:16 AM SuperQ Spectrometer error: 3,0,18,0,0 Cap did not open on open command.
4502 5/25/2006 8:52:13 AM SuperQ Spectrometer warning: 2,14,0,0 Bad vacuum; above warning level.
2、有时装入试样后,马上又送出试样
9999 5/25/2006 5:49:46 PM SuperQ Measurement aborted due to spectrometer error; Sample identification k5-1230
4501 5/25/2006 5:49:46 PM SuperQ Spectrometer error: 3,15,13,0,0 Meas. abort; sample loading mech. in bad position.
3、安装后,就出现的错误提示
4516 5/26/2006 7:21:52 AM SuperQ Spectrometer disconnected because of a connection TIMEOUT.
4514 5/26/2006 7:21:52 AM SuperQ Aftercare info: SpmStatusChn: SpmTUBE-H,
4501 5/26/2006 7:21:00 AM SuperQ Spectrometer error: Channel error, read invalid restricted string.
