第一次成功投稿
  • li8888lili8888
    2012/12/09
    《分析科学学报》
论文写作和投稿
  • 5月份开始写我的外文文章,因为前一次有一定的经验,为什么这样说呢,是由于之前写的有关AZ31B文章屡战屡败,投了好多次,都失败了,到后来实在不行了,就搁置了。二这篇是写复合材料的。是我大学的一个创新大赛的成果。
    现在总结一下,想写一篇。有了前一次没有成功的经验,我这次谨慎了好多。但是仍然很担心。当时写的时候就很用功的查,只要是不是很有把握的单词,就认真的去找相似的用法。我常用的是有道词典,我感觉挺不错的,我的这一篇文章,大多要归咎于他。写好后,就大胆的选了一个影响因子不高的,想着能被SCI收录就行,于是果断的在71日,我就投了稿,接下来就是焦急的等待。从技术审核到with editor,再到underreview,到Completed,到最后的Completed: Accepted,一步步都很艰辛,我感觉,但是很庆幸,我艰难的走出来了,走过来了。因为我的英语并不是很好。等看到Accepted,我激动万分,我高兴的想告诉每个人。想让每个人和我一起分享我的快乐。
    这是Materials Science and Technology的投稿网址:http://mst.edmgr.com/
    以下是我投稿的稿件信件摘录如下:
    这是我注册成功的:
    Dear Mr. yangThank you for registering for the Editorial Manager online submission and peer review tracking system for Materials Science and Technology.Here is your username and confidential password, which you need to access the Editorial Manager at http://mst.edmgr.com/.。。。。。。。。
    这是我投稿的PDF成功生成
    Dear Mr. yangThe PDF for your submission "Tungsten Arc Welded Magnesium Alloy AZ31B Plates" is ready for viewing. Your PDF must be approved in order to complete the submission process and send the manuscript to the Materials Science and Technology editorial office. Thank you for your time and patience.
    这是文章编号
    Dear Mr. yangYour submission "。。。。" to Materials Science and Technology has been assigned the manuscript number: MST1。。。.
    The paper is now with an Editor and we will contact you again once referees' comments are received. You will be able to check on the progress of your paper by logging on to Editorial Manager as an author.
    Thank you for submitting your work to this journal.
    这是评审意见;
    We now have referees' comments on the above paper. I am pleased to tell you that the work is of interest, but regret to say that the paper is not considered suitable in its present form for publication in Materials Science and Technology. The reasons are detailed in the comments below. You will see that a number of general and specific points are mentioned which necessitate extensive rewriting of the paper. Please consider how you wish to proceed. If you are able to revise the paper extensively, to deal in full with all the points mentioned, we shall be willing to consider the position further.
    You will see a menu item entitled Submission Needing Revision.
    Your submission record may be viewed there.
    这是我的回复:
    Dear Editor:We thank you very much for giving us an opportunity to revise our manuscript, we appreciate editor and reviewers very much for their positive and constructive comments and suggestions on our manuscript entitled “。。。。”. (ID: 。。。。).
    We have studied reviewer’s comments carefully and have made revision which marked in red in the paper. We have tried our best to revise our manuscript according to the comments. Attached please find the revised version, which we would like to submit for your kind consideration.
    We would like to express our great appreciation to you and reviewers for comments on our paper.
    Looking forward to hearing from you.
    Thank you and best regards.
    这是录用的信件
    Dear Mr. yangThank you for submitting a revised version of the above submission and your response to the comments made by the reviewers. I am pleased to confirm that the paper is accepted for publication in Materials Science and Technology. It was accepted on 29 Oct 2012You will shortly receive an email detailing log-in instructions for ManeyTrack - Maney Publishing's web-based production tracking system. Via ManeyTrack you will be able to view the production status of your article at any time, and also have the option to place orders for offprints, issue copies (if the journal has a print offering) and to make your article open access via Maney's MORE OpenChoice offering (see below).
    Thank you for submitting your work to Materials Science and Technology.
    With kind regards
    The Editor
    当时吓得不敢看,是下午6点刚吃完饭,回来,无意中在看手机,弹出来一个消息,是闭着眼睛看的,心里在祈祷不要悲剧了。
    看到Thank you for submitting a revised version of the above submission and your response to the comments made by the reviewers. I am pleased to confirm that the paper is accepted for publication in Materials Science and Technology. It was accepted on 29 Oct 2012这个,我和同学激动地拥抱了。
    太不容易了,真的。此时的我,只想说,谢谢大家,谢谢所有关心我的人。
    总的来说,换算顺利,真的。没有太艰难,只是压力挺大的,心里要承受很多。特别是等邮件信息的时候,因为前一次的失败投稿,在心里有一个阴影,所以搞得我比较紧张。嘿嘿,文章被录是我下一步的动力,我会继续努力,不断的加油,学好英语,学好专业。加油!!!
  • 该帖子已被版主-省部重点实验室加10积分,加2经验;加分理由:欢迎来到论文板块交流
  • hza123
    第1楼2012/12/09
    英文目前还没想投过,不过今年中文的写了好几篇,其中2篇都是被拒后,大修后再投稿接收的,后面一篇就是直接录取的,所以体会就是越败越战,拒绝有时候也会让自己更进步,呵呵。
  • 该帖子已被版主-省部重点实验室加2积分,加2经验;加分理由:欢迎来到论文板块交流
  • li8888lili8888
    第2楼2012/12/09
    恩,是呀,看好你。大哥,你在哪个公司?
    hza123(hza123) 发表:英文目前还没想投过,不过今年中文的写了好几篇,其中2篇都是被拒后,大修后再投稿接收的,后面一篇就是直接录取的,所以体会就是越败越战,拒绝有时候也会让自己更进步,呵呵。
  • hza123
    第3楼2012/12/09
    小单位上班
    li8888lili8888(li8888lili8888) 发表:恩,是呀,看好你。大哥,你在哪个公司?
  • li8888lili8888
    第5楼2012/12/09
    谦虚了!!!
    hza123(hza123) 发表:小单位上班
  • li8888lili8888
    第6楼2012/12/09
    谢谢了
    yuduoling(yuduoling) 发表:恭喜楼主。
  • 忘记guoqu
    第7楼2012/12/09
    持之以恒就会有成功的一天,向你学习了楼主。
  • gbluo324
    第8楼2012/12/10
    写的很详细,不错了,发表了就行,以后会逐步提高。
  • li8888lili8888
    第9楼2012/12/10
    说的很对,共同学习
    忘记guoqu(v2652341) 发表:持之以恒就会有成功的一天,向你学习了楼主。
  • li8888lili8888
    第10楼2012/12/10
    谢谢罗哥,以后多帮忙哦
    gbluo324(gbluo324) 发表:写的很详细,不错了,发表了就行,以后会逐步提高。
