向大家请教一个戴安ICS-5000的软件(变色龙6.80版)操作问题
离子色谱(IC)
  • 色谱仪型号:戴安ICS-5000,自动进样器AS-DV
    软件版本:变色龙6.80
    程序设置的目的是:
    第1个程序——只分析阴离子,与阴离子分析无关的部件处于关闭状态。
    第2个程序——阴阳离子同时分析;
    现在的问题是:阴阳离子同时分析是没有问题的。但是第1个程序,在实际操作中出现错误,无法运行。
    下面把这两个程序都贴出来,希望有大虾指点一二。
    阴离子进样
    Column_TC.AcquireExclusiveAccess
    Pump_2.Pressure.LowerLimit = 200 [psi]
    Pump_2.Pressure.UpperLimit = 3000 [psi]
    Pump_2.MaximumFlowRamp = 6.00 [ml/min2]
    Pump_2.%A.Equate = "%A"
    Pump_2.%B.Equate = "%B"
    Pump_2.%C.Equate = "%C"
    Pump_2.%D.Equate = "%D"
    Pump_1.Pressure.LowerLimit = 200 [psi]
    Pump_1.Pressure.UpperLimit = 3000 [psi]
    Pump_1.MaximumFlowRamp = 6.00 [ml/min2]
    Pump_1.%A.Equate = "%A"
    Pump_1.%B.Equate = "%B"
    Pump_1.%C.Equate = "%C"
    Pump_1.%D.Equate = "%D"
    EGC_1.CR_TC = Off
    EGC_2.CR_TC = On
    DeliverSpeed = 4.0 [ml/min]
    DelayVolume = 125 [μl]
    FlushFactor = 10
    DeliverSample
    Sampler.LoadPosition
    DeliverSample Volume=Full
    EndSamplePrep
    CDet2.Data_Collection_Rate = 5.0 [Hz]
    CDet2.Temperature_Compensation = 1.7 [%/°C]
    Cell2Heater.Mode = On
    Cell2Heater.TemperatureSet = 35.00 [°C]
    Column_TC.Mode = On
    Column_TC.TemperatureSet = 30.00 [°C]
    Suppressor1.Type = CSRS_4mm
    Suppressor1.CurrentSet = 80 [mA]
    Suppressor1.Mode = off
    Suppressor2.Type = ASRS_4mm
    Suppressor2.CurrentSet = 100 [mA]
    EGC_1.Concentration = 20.00 [mM]
    EGC_1.Mode = Off
    EGC_1.Curve = 5
    EGC_2.Concentration = 30.00 [mM]
    EGC_2.Curve = 5
    Pump_1.Flow = 1.200 [ml/min]
    Pump_1.Motor = Off
    Pump_1.%B = 0.0 [%]
    Pump_1.%C = 0.0 [%]
    Pump_1.%D = 0.0 [%]
    Pump_1.Curve = 5
    Pump_2.Flow = 1.200 [ml/min]
    Pump_2.%B = 0.0 [%]
    Pump_2.%C = 0.0 [%]
    Pump_2.%D = 0.0 [%]
    Pump_2.Curve = 5
    0.000 CDet2.Autozero
    Wait CycleTimeState
    Inject
    CD_2.AcqOn
    0.500 BeginOverlap
    10.000 CD_2.AcqOff
    Column_TC.ReleaseExclusiveAccess
    End
    阴阳离子同时分析:
    InjectValve_1.LoadPosition
    InjectValve_2.LoadPosition
    EGC_1.CR_TC = On
    EGC_2.CR_TC = On
    FlushFactor = 10
    DeliverSample
    EndSamplePrep
    CDet1.Data_Collection_Rate = 5.0 [Hz]
    CDet1.Temperature_Compensation = 1.7 [%/°C]
    CellHeater.Mode = On
    CellHeater.TemperatureSet = 35.00 [°C]
    Column_TC.Mode = On
    EGC_1.Curve = 5
    EGC_2.Curve = 5
    Pump_1.%B = 0.0 [%]
    Pump_1.%C = 0.0 [%]
    Pump_1.%D = 0.0 [%]
    Pump_1.Curve = 5
    Pump_2.%B = 0.0 [%]
    Pump_2.%C = 0.0 [%]
    Pump_2.%D = 0.0 [%]
    Pump_2.Curve = 5
    CDet1.Autozero
    Wait CycleTimeState
    Inject
    CD_2.AcqOn
    CD_1.AcqOn
    0.500 BeginOverlap
    12.000 CD_2.AcqOff
    CD_1.AcqOff
    End
  • yfytap
    第1楼2012/12/19
    阴阳离子同时分析可以操作?
  • yzulcl
    第2楼2012/12/20
    代码的问题还是问问戴安的工程师吧
    传说中的双泵、双阀、双柱、双检测器的配置,等于就是两台仪器并联了啊。而且还配了自动进样器,超豪华配置啊。
    阴离子有EGC不奇怪,阳离子也有EGC,长见识了。生成的淋洗液是什么?硫酸吗?
  • moviefan
    第3楼2012/12/21
    阳离子淋洗液是MSA,甲基磺酸。我们的自动进样器(AS-DV型)配低档了,现在相当于两台仪器串联而不是并联,和我们当初的技术要求不符,仪器公司会给我们换成AS-AP型的自动进样器,这个才是和主机匹配的型号。
    yzulcl(yzulcl) 发表:代码的问题还是问问戴安的工程师吧
  • moviefan
    第4楼2012/12/21
    双泵、双柱、双抑制器/检测器系统,相当于两台机,可以同时分析同一个样品的阴阳离子,但校准曲线要先后分别测定。我们配这台机主要是为了分析大气降水。还有一台旧的万通离子色谱也是双系统的。
    yfytap(yfytap) 发表:阴阳离子同时分析可以操作?
  • 不能说
    第5楼2012/12/22
    最好把你的错误信息给贴出来,要不怎么找原因
  • moviefan
    第6楼2012/12/26
    问题已经基本解决了,多谢大家。
  • zhuxinchun1979
    第8楼2014/11/22
    6.8版的谁有破解版的
