序号 | 中文 | 英文 | EC No. | CAS No. | 列入候选原因 |
01 | 颜料黄41 | Pyrochlore, antimony lead yellow | 232-382-1 | 8012-00-8 | 生殖毒性(Article 57 c); |
02 | 2-甲氧基-5-甲基苯胺 | 6-methoxy-m-toluidine (p-cresidine) | 204-419-1 | 120-71-8 | 致癌性 (Article 57 a) |
03 | 全氟十一烷酸 | Henicosafluoroundecanoic acid | 218-165-4 | 2058-94-8 | vPvB -- 高持久性、高生物积累性(Article 57 e) |
04 | 甲基六氢苯酐、4-甲基六氢苯酐、甲基六氢化邻苯二甲酸酐、3-甲基六氢苯二甲酯酐 | Hexahydromethylphthalic anhydride [1], Hexahydro-4-methylphthalic anhydride [2], Hexahydro-1-methylphthalic anhydride [3], Hexahydro-3-methylphthalic anhydride [4] [The individual isomers [2], [3] and [4] (including their cis- and trans- stereo isomeric forms) and all possible combinations of the isomers [1] are covered by this entry] | 247-094-1, 243-072-0, 256-356-4, 260-566-1 | 25550-51-0, 19438-60-9, 48122-14-1, 57110-29-9 | 同等程度的关注:可能严重影响环境(Article 57 f) |
05 | 六氢邻苯二甲酸酐、c六氢-1,3-异苯并呋喃二酮 、反-1,2-环己烷二羧酸酐 | Cyclohexane-1,2-dicarboxylic anhydride [1], cis-cyclohexane-1,2-dicarboxylic anhydride [2], trans-cyclohexane-1,2-dicarboxylic anhydride [3] [The individual cis- [2] and trans- [3] isomer substances and all possible combinations of the cis- and trans-isomers [1] are covered by this entry] | 201-604-9, 236-086-3, 238-009-9 | 85-42-7, 13149-00-3, 14166-21-3 | 同等程度的关注:可能严重影响环境(Article 57 f) |
06 | 二丁基二氯化锡 | Dibutyltin dichloride (DBTC) | 211-670-0 | 683-18-1 | 生殖毒性(Article 57 c); |
07 | 氟硼酸铅 | Lead bis(tetrafluoroborate) | 237-486-0 | 13814-96-5 | 生殖毒性(Article 57 c); |
08 | 硝酸铅 | Lead dinitrate | 233-245-9 | 10099-74-8 | 生殖毒性(Article 57 c); |
09 | 硅酸铅 | Silicic acid, lead salt | 234-363-3 | 11120-22-2 | 生殖毒性(Article 57 c); |
10 | 对氨基偶氮苯 | 4-Aminoazobenzene; | 200-453-6 | 60-09-3 | 致癌性 (Article 57 a) |
11 | 钛酸铅锆 | Lead Titanium Zirconium Oxide | 235-727-4 | 12626-81-2 | 生殖毒性(Article 57 c); |
12 | 氧化铅 | Lead oxide (lead monoxide) | 215-267-0 | 1317-36-8 | 生殖毒性(Article 57 c); |
13 | 邻甲基苯胺 | o-Toluidine | 202-429-0 | 95-53-4 | 致癌性 (Article 57 a) |
14 | 3-乙基-2-甲基-2-(3-甲基丁基)噁唑烷 | 3-ethyl-2-methyl-2-(3- methylbutyl)-1,3-oxazolidine | 421-150-7 | 143860-04-2 | 生殖毒性(Article 57 c); |
15 | 掺杂铅的硅酸钡 | Silicic acid (H2Si2O5), barium salt (1:1), lead-doped | 272-271-5 | 68784-75-8 | 生殖毒性(Article 57 c); |
16 | 碱式碳酸铅 | Trilead bis(carbonate)dihydroxide | 215-290-6 | 1319-46-6 | 生殖毒性(Article 57 c); |
17 | 呋喃 | Furan | 203-727-3 | 110-00-9 | 致癌性 (Article 57a) |
18 | N,N-二甲基甲酰胺 | N,N-dimethylformamide; | 200-679-5 | 68-12-2 | 生殖毒性(Article 57 c); |
19 | 辛基酚聚醚-9,包括界定明确的物质以及UVCB物质、聚合物和同系物。 | 4-(1,1,3,3-tetramethylbutyl)phenol, ethoxylated [covering well-defined substances and UVCB substances, polymers and homologues] | - | - | 同等程度的关注:可能严重影响环境(Article 57 f) |
20 | 分支或线性的壬基酚,含有线性或分支、共价绑定苯酚的9个碳烷基链的物质,包括UVCB物质以及任何含有独立或组合的界定明确的同分异构体的物质 | 4-Nonylphenol, branched and linear [substances with a linear and/or branched alkyl chain with a carbon number of 9 covalently bound in position 4 to phenol, covering also UVCB- and well-defined substances which include any of the individual isomers or a combination thereof] | - | - | 同等程度的关注:可能严重影响环境(Article 57 f) |
21 | 4,4'-二氨基-3,3'-二甲基二苯甲烷 | 4,4'-methylenedi-o-toluidine | 212-658-8 | 838-88-0 | 致癌性 (Article 57 a) |
22 | 硫酸二乙酯 | Diethyl sulphate | 200-589-6 | 64-67-5 | 致癌性 (Article 57 a); 致突变(Article 57 b) |
23 | 硫酸二甲酯 | Dimethyl sulphate | 201-058-1 | 77-78-1 | 致癌性 (Article 57 a); |
24 | 碱式硫酸铅 | Lead oxide sulfate | 234-853-7 | 12036-76-9 | 生殖毒性(Article 57 c); |
25 | 钛酸铅 | Lead titanium trioxide | 235-038-9 | 12060-00-3 | 生殖毒性(Article 57 c); |
26 | 碱式乙酸铅 | Acetic acid, lead salt, basic | 257-175-3 | 51404-69-4 | 生殖毒性(Article 57 c); |
27 | 二盐基邻苯二甲酸铅 | [Phthalato(2-)]dioxotrilead | 273-688-5 | 69011-06-9 | 生殖毒性(Article 57 c); |
28 | 十溴二苯醚 | Bis(pentabromophenyl) ether (DecaBDE) | 214-604-9 | 1163-19-5 | PBT-- 持久性、生物积累性与毒性(Article 57 d); vPvB -- 高持久性、高生物积累性(Article 57 e) |
29 | N-甲基乙酰胺 | N-methylacetamide | 201-182-6 | 79-16-3 | 生殖毒性(Article 57 c); |
30 | 地乐酚 | Dinoseb (6-sec-butyl-2,4-dinitrophenol) | 201-861-7 | 88-85-7 | 生殖毒性(Article 57 c); |
31 | 乙二醇二乙醚 | 1,2-Diethoxyethane | 211-076-1 | 629-14-1 | 生殖毒性(Article 57 c); |
32 | 三碱式硫酸铅 | Tetralead trioxide sulphate | 235-380-9 | 12202-17-4 | 生殖毒性(Article 57 c); |
33 | 邻苯二甲酸正戊基异戊基酯 | N-pentyl-isopentylphtalate | - | 776297-69-9 | 生殖毒性(Article 57 c); |
34 | 双(十八酸基)二氧代三铅 | Dioxobis(stearato)trilead | 235-702-8 | 12578-12-0 | 生殖毒性(Article 57 c); |
35 | 四乙基铅 | Tetraethyllead | 201-075-4 | 78-00-2 | 生殖毒性(Article 57 c); |
36 | 氧化铅与硫酸铅的复合物 | Pentalead tetraoxide sulphate | 235-067-7 | 12065-90-6 | 生殖毒性(Article 57 c); |
37 | 全氟十三酸 | Pentacosafluorotridecanoic acid | 276-745-2 | 72629-94-8 | vPvB -- 高持久性、高生物积累性(Article 57 e) |
38 | 全氟十二烷酸 | Tricosafluorododecanoic acid | 206-203-2 | 307-55-1 | vPvB -- 高持久性、高生物积累性(Article 57 e) |
39 | 全氟代十四酸 | Heptacosafluorotetradecanoic acid | 206-803-4 | 376-06-7 | vPvB -- 高持久性、高生物积累性(Article 57 e) |
40 | 溴代正丙烷 | 1-bromopropane (n-propyl bromide) | 203-445-0 | 106-94-5 | 生殖毒性(Article 57 c); |
41 | 甲氧基乙酸 | Methoxy acetic acid | 210-894-6 | 625-45-6 | 同等程度的关注:可能严重影响环境(Article 57 f)
42 | 2,4-二氨基甲苯 | 4-methyl-m-phenylenediamine (toluene-2,4-diamine) | 202-453-1 | 95-80-7 | 致癌性 (Article 57 a) |
43 | 环氧丙烷 | Methyloxirane (Propylene oxide) | 200-879-2 | 75-56-9 | 致癌性 (Article 57 a); 致突变(Article 57 b) |
44 | 磷酸氧化铅 | Trilead dioxide phosphonate | 235-252-2 | 12141-20-7 | 生殖毒性(Article 57 c); |
45 | 邻氨基偶氮甲苯 | o-aminoazotoluene | 202-591-2 | 97-56-3 | 致癌性 (Article 57 a) |
46 | 支链和直链1,2-苯二羧二戊酯 | 1,2-Benzenedicarboxylic acid, dipentylester, branched and linear | 284-032-2 | 84777-06-0 | 生殖毒性(Article 57 c); |
47 | 4,4'-二氨基二苯醚 | 4,4'-oxydianiline and its salts | 202-977-0 | 101-80-4 | 致癌性 (Article 57 a); 致突变(Article 57 b) |
48 | 四氧化三铅 | Orange lead (lead tetroxide) | 215-235-6 | 1314-41-6 | 生殖毒性(Article 57 c); |
49 | 4-氨基联苯 | Biphenyl-4-ylamine | 202-177-1 | 92-67-1 | 致癌性 (Article 57 a) |
50 | 邻苯二甲酸二异戊酯 | Diisopentylphthalate (DIPP) | 210-088-4 | 605-50-5 | 生殖毒性(Article 57 c); |
51 | C16-18-脂肪酸铅盐 | Fatty acids, C16-18, lead salts | 292-966-7 | 91031-62-8 | 生殖毒性(Article 57 c); |
52 | 偶氮二甲酰胺 | Diazene-1,2-dicarboxamide (C,C'-azodi(formamide)) | 204-650-8 | 123-77-3 | 同等程度的关注:可能严重影响环境(Article 57 f) |
53 | 亚硫酸铅(II) | Sulfurous acid, lead salt, dibasic | 263-467-1 | 62229-08-7 | 生殖毒性(Article 57 c); |
54 | 氨基氰铅盐 | Lead cynamidate | 244-073-9 | 20837-86-9 | 生殖毒性(Article 57 c); |
