happyjyl
第1楼2006/06/05
倩碧日用防晒隔离霜SPF25
water(aqua purificata)purified
octyldodecyl neopentanoate
titanium dioxide
butylene glycol
cyclomethicone
steareth-2
silica
behenoxy dimethicone
zinc oxide
tricaprylin
lecithin
magnesium ascorbyl phosphate
bisabolol
pantethine
tocopheryl acetate
polyglyceryl-6 ricinoleate
isopropyl titanium triisostearate
trifluoromethyl ci-4 alkyl dimethicone
tricaprylyl citrate
sorbitan tristearate
silver borosilicate
camosic acid
carnosol extract
tococysteamide
peg-40 stearate
ceteth-2
dimethicone copolyol
stearate-20
sodium stearate
aluminum stearate
bariumsulfate
magnesium aluminum
xanthan gum
citric acid
disodium EDTA
bht
iron oxide(ci77491,ci77492,ci77499)[iln 10592]
用的是物理防晒原料,防护力还可以.
剂型比较复杂,大量的酯,卵磷脂和硅酮类,可能这样的配方比较难以模仿吧.
几个有效成分还可以,抗敏,抗氧化,甚至有美白成分MAP.
缺点就是泛白,基本上也是大多数物理防晒的缺点.
倩碧TOTAL TURN AROUND 宛若新生
INGREDIENTS:
WATER PURIFIED, CYCLOMETHICONE, DIMETHICONE, BUTYLENE GLYCOL, POLYSILICONE-11, SQUALANE, PEG-8, AMMONIUM ACRYLOYLDIMETHYLTAURATE/VP COPOLYMER, TRITICUM VULGARE (WHEAT) GERM EXTRACT, MIXED SOYA PHOSPHOLIPIDS, HORDEUM VULGARE (BARELY) EXTRACT, SALVIA OFFICINALIS (SAGE) POWDER, PALMITOYL PENTAPEPTIDE-3, SODIUM HYALURONATE, ACETYL GLUCOSAMINE, CAFFEINE, TOCOPHERYL ACETATE, POTASSIUM CHOLESTEROL SULFATE, LINOLEIC ACID, ARGININE, SALICYLIC ACID, CHOLESTEROL, POLYSORBATE 20, POLYACRYLAMIDE, NYLON-12, C13-14 ISOPARAFFINE, SILICA, GLYCERIN, LAURETH-7, CARBOMER, XANTHAN
这个产品的成分觉得还不错,吸水剂用了丁二醇和鲨烯玻尿酸,不过用peg-8有一点致粉刺危险。油性锁水剂没用合成酯而用的是有角质修复效果的亚仁油酸,值得大力表扬。
是一款效果中上,性价比也OK的有去角质效果的霜,但是其功能性和安全性很大程度决定于水杨酸的含量,不建议每天使用,也不建议皮肤薄的人使用。
雪肌精乳液配方:
water(aqua),alcohol,butylene glycol,glycerin,dipropylene gllycol dicaprate,dimethicone,cetyl alcohol,dipentaerythrityl hexahydroxystearate/stearate/rosinate,squalane,angelica acutiloba root extract,colx lacryma-jobi(job's tears)seed extract,gentiana lutea extract,hamamelis virginiana(witch hazel)extract,inula britannica flower extract,melothria heterophylla extract,paeonia albiflora root extract,polyphosphorylcholine glycol acrylate,tocopheryl acetate,triticum vulgare(wheat)germ oil.c13-16 isoparaffin,cellulose gum,cirtic acid,disodium edta,disodium phosphate,ethylhexyl methoxycinnamate,hydrogenated lecithin,hydrogenated rapeseed glyceride,laureth-7,peg-8,polyacrylamide,polysorbate80,sodium hydroxide,sodium methyl stearoyl tqurate,sorbitan stearate,ethylparaben,methylparaben,propylparaben,fragrance(parfum)
这个乳液配方除了高含量酒精,和一点点的氢氧化钠以外,还算是比较安全,主要用多元醇做保湿剂,对年轻皮肤是够用了。清爽度普通,因为和水清新一样,加了一点紫外线吸收剂,晚上用皮肤有点负担。
总体中等,性价比还是不错。
happyjyl
第2楼2006/06/05
HR保湿面膜配方:
Aqua/water,glycerin,hydrogenated polyisobutene,butyrospermum parkll/butyrospermum parkll fruit,dimethicone,peg-2 dilaurate,peg-4 laurate,tea-carbomet,dimethiconol,sodium chondroitin sulfate,codium tomentosum/codium tomentosum extract,collagen,propylene glycol,chitosan,parfum/fragrance,imidazolidinyl urea,iodopropynyl butylcarbamate,chilorphenesin,phnoxyethanol,cl 19140/yellow 5,xl 42090/blue 1,cl88901/titanium dioxide,mica code f.i.l:b5663/1
总体感觉中上,用多元醇,peg共聚体做亲水保湿剂,也有乳木果油和胶元蛋白,没用什么合成酯和多余的添价剂是优点。
成分精简,适用防卫广,效果也还不错,性价比OK。
ANEW RETROACTIVE Age Reversal Face Cream
water ,
glycerin ,
cyclomethicone ,
c12-13 alkyl lactate ,
c12-15 alkyl benzoate ,
glyceryl polymethacrylate
silica ,
benzyl alcohol ,
phytol ,
sunflower (helianthus annuus) seed extract ,
plankton extract ,
adenosine cyclic phosphate ,
hydrolyzed milk protein
sodium hyaluronate ,
andrographolide ,
isophytol ,
panthenol ,
polydecene ,
hydrogenated polyisobutene ,
dimethicone (and) trimethylsiloxysilicate ,
dimethicone crosspolymer ,
behenyl alcohol ,
steareth-2 ,
peg-40 stearate ,
glyceryl stearate ,
carbomer ,
acrylates/c10-30 alkyl acrylate crosspolymer ,
benzophenone-4 ,
butylene glycol ,
methylparaben ,
fragrance ,
sodium hydroxide disodium edta ,phosphoric acid ,
ext.d&c violet no.2 ,
fd&c blue no.1,
这个是avon新活吧,成分活性还是比较理想的,海洋原生质,乳蛋白,玻尿酸,葵花子油,有一定改善效果。
但是缺点也很突出,用了benzyl alcohol作为促皮吸收剂,这是有争议的方式。然后氢氧化钠和benzopheno-3防晒剂的存在也让安全性下降了不少。
不建议敏感皮肤使用。
DIOR的HYDRA MOVE,SPF10
Aqua.glycerin.squalane.butylene glycol.steareth-21.glyceryl stearate.phenoxyethanol.parfum.acrylates.c10-30 alkyl acrylate crosspolymer.chlorphenesin.dimethicone.stearic acid.methylparaben.propylene glycol.polymethyl methacrylate.cetyl alcohol.disodium edta.mel.stearyl alcohol.tocopheryl acetate.alcohol.sodium hydroxide.calcium gluconate.sodium hyaluronate.ajuga turkestanica extract.carbomer.ceramide 2.malva sylvestris extract.sodium polyacrylate.butylparaben.ethylparaben.porpylparaben.isobutylparaben.bht.
主要保湿成分不错,也有玻尿酸,神经酰胺,保湿力出色。
但是缺点是防腐剂香料过高,有氢氧化钠,合成酯含量也高了点。
一款基础保湿霜,适合中干性不敏感皮肤。
H2O 8杯水
Purified Water(Aqua), Glyceryl Polymethacrylate, Propylene Glycol, Glycereth7
Dimethicone, Glycosaminoglycans, Phospholipids, Maris Sai (Dead sea salts:Potassium, Magnesium, Calcium, Sodium)
Sea lettuce (Ulva lactuca) extract, Sea fennel (Crithmum maritimum) extract
Bladderwrack (Fucus vesiculosus) extract, Panthenol (Proviamin B), Retinyl palmitate (Vitamin A palmitate)
Ascorbic acid (Vitamin C), Tocopherol acetate (vitamin E acetate)
Zinc PCA, Benzophenone-4, Coriander (Coriandrum Sativum), Dimethicone copolyol
Lavender (Lavandula angustifolia), Triethanolamine, Dioctyl sodium sulfosuccinate
Carbomer, Trisodium EDTA, Imidazolidinyl urea, Methylchloroisothiazolinone, Methylisothiazolinone
Methyldihydrojasmonate, Cyclamen aldehyde, Linalool, Floralozone, Propylparaben
Methylparaben, Diazolidinyl urea, FD&C blue #1(Cl42090
我觉得八杯水和水磁场是两个流派,象这个八杯水,没有用太多顺滑剂,感觉会比较粘,而水磁就很清爽好推。
它最大亮点是用了海盐和多种维生素,护肤效果比水磁要积极一些,功效也要理想一些。
同时含有ZINC PCA一个不错的改善油脂分泌情况的成分。
不过用了防晒成分,小小缺憾。
如果不介意这种质感,我觉得比水磁场的改善效果要理想。水磁场只是一款单纯保湿霜。
