showmethemoney
第2楼2013/01/17
看看这一段话,难道是我理解错了?
ULTIMA 2 is equipped with the patented High Dynamic Detection system, exclusively available from HORIBA Scientific. The dynamic range is enhanced, with up to 10 orders of magnitude. The adjustment of the gain is done within milliseconds without hysteresis, allowing full spectrum acquisi-tion in less than 3 minutes. Measurement of trace and major elements is possible in a single run for
qualitative and semi-quantitative analysis purposes using optional Image Navigator.
