异恶草松(clomazone)风险评估报告
农残检测
  • 附件请参考。
附件:
  • 该帖子已被版主-MMYG加2积分,加2经验;加分理由:分享
  • MMYG
    第1楼2013/02/16
    检测这些农药的多么?第一次听说这个
  • 西北风
    第2楼2013/02/19
    学习了,农药风险评估是个很复杂的工程。
  • 雾非雾
    第3楼2013/02/27
    可滅蹤(Clomazone) 農藥有效成分檢驗方法
  • 雾非雾
    第4楼2013/02/27
    别名:
    Clomazone
    化合物名称:Clomazone
    化合物名称 (CAS):2-[(2-chlorophenyl)methyl]-4,4-dimethyl-3-isoxazolidinone
    化合物名称 (IUPAC):2-[(2-chlorophenyl)methyl]-4,4-dimethyl-1,2-oxazolidin-3-one
    分子式:C12H14ClNO2
    分子量:239.69806
    Log P(已计算):
    Log P-AA:
    2.5
    分离模式标题色谱柱
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-5msZebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-5MSiZebron™ ZB-5MSi, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-MR1Zebron™ ZB-MultiResidue™-1, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-MR2Zebron™ ZB-MultiResidue™-2, gc Cap. Column 30 m x 0.25 mm x 0.20 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-1701PZebron™ ZB-1701, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-35Zebron™ ZB-35, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-XLBZebron™ ZB-XLB, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Gas ChromatographyHalogenated Pesticides Mix # 5 on ZB-50Zebron™ ZB-50, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea
    Reversed Phase ChromatographyiMethod: Screening >350 Pesticides from Food & Feed According to Regulation (EC) No. 396/2005Synergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea
    Reversed Phase ChromatographyiMethod™ Food - Screening of 535 Pesticides by QuEchERS and $$lc/MS/MSSynergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea
    技术:gc,HP$$lc
    分离模式:Gas Chromatography,Reversed Phase Chromatography
  • liuquan2008
    第5楼2013/02/27
    我们在里刚好也生产啊
  • 雾非雾
    第6楼2013/02/27
    US EPA-Pesticides; Clomazone
  • 雾非雾
    第8楼2013/02/28
    Study of the degradation of the herbicide clomazone in distilled and in irrigated rice field waters using HPLC-DAD and gc-MS
  • 雾非雾
    第9楼2013/02/28
    Development and validation of a high-performance liquid chromatographic method for the determination of clomazone residues in surface water
  • 雾非雾
    第10楼2013/02/28
    Environmental Chemistry Methods: Clomazone
