想买台安捷伦1260,下面的报价合理吗,请大侠给点建议!
综合仪器采购
  • 想买台安捷伦1260,
    代理商报价如下,请高手看看合理吗,有哪些配件/耗材可以增减?望高手多多指点,谢谢!
    安捷伦1260 制备液相色谱系统二极管阵列检测器)
    ITEMPART NO.&DESCRIPTIONUNIT(US$)QTYTOTAL( US$ )
    泵单元
    1G1361A 高压制备泵23,981.25123,981.25
    Agilent 1260 Infinity Preparative PumpIncludes preparative pump, solvent cabinet, solvent bottle 2 l, purge valve, 1-m CAN cable and seal wash with peristaltic pump.
    2G1391A 高压制备泵梯度扩展泵23,981.25123,981.25
    Agilent 1260 Infinity Preparative pump gradient extensionIncludes preparative pump, gradient kit, solvent bottle 2 l, purge valve, 0.5-m CAN cable and seal wash with peristaltic pump.
    自动进样器
    1G2260A 制备型自动进样器(标配2mL定量环)20,582.50120,582.50
    Agilent 1260 Infinity Preparative Autosampler
    2G2260-68711 5mL定量环522.501522.50
    5ml Multi draw loop for use with G2260A
    馏分收集器
    1G1364B 制备型自动馏分收集器13,857.86113,857.86
    Agilent 1260 Fraction Collector (Preparative scale). Includes delay sensor
    2G1364-84523 样品盘528.751528.75
    Tray holding 40 tubes, 30 x 100mm, 50ml
    3G1364-84525 样品盘528.751528.75
    Tray holding 126 tubes, 16x100mm,14ml
    45042-6458 样品瓶66.07166.07
    Round bottom glass vial, 30x100mm 100/PK
    55022-6532 样品瓶62.50162.50
    Test Tube, 16 x 100 mm, 250/pk
    检测器
    1G1315D 二极管阵列检测器19,510.36119,510.36
    1260 Infinity Diode Array Detector VL. Provides 20 Hz data acquisition rate and RFID tags for flow cell and lamp. Includes RFID tracking technology for flow cells and UV lamp. No flow cell included.
    2G1315D-024 制备流通池2,868.7512,868.75
    Prep flow cell 0.3mm 20 bar quartz
    软件
    1M8307AA 液相色谱化学工作站操作软件(中英文可选)8,636.6518,636.65
    ChemStation for liquid chromatography. For control, data acquisition and evaluation of chromatographic data from one liquid chromatograph(含光谱软件).
    色谱柱
    1883975-202 SB-C18 色谱柱, 9.4 x 150 mm5u 1556.25 11,556.25
    SB-C18, 5um, 9.4 x 150 mm
    2870150-902 -C18 色谱柱, 21.2x150mm,5u 3210.00 13,210.00
    PrepHT ,SB-C18,21.2x150mm,5u Crt
    3840140-901 半制备柱保护柱卡套383.75 1383.75
    Semiprep Guard Hardware Kit
    4820675-115 半制备柱保护柱柱芯340.00 1340.00
    SB-C8 Prep Reliance Grd Col 9.4x15 2/PK
    5820400-901 制备柱卡套453.75 1453.75
    PrepHT,Hardware,21.2mm Crt.End Ftg 2/PK BC
    6820444-901 制备柱保护柱卡套428.75 1428.75
    PrepHT Guard Hardware Kit BC 263.00
    7820212-920 制备柱保护柱柱芯472.50 1472.50
    PrepHT ZORBAX SB-C18 Grd Crt, 5um 2/PK
    备件及耗材
    1G1361-60012 出入口单向阀芯145.002290.00
    Valve assy, inlet/outlet for prep pump
    2G1361-60006 过滤组件742.371742.37
    Filter Screw Multi AY
    35065-9926 不锈钢毛细软管204.901204.90
    Flex capillary,0.5×800mm no fittings
    45062-2462 聚四氟乙烯管线46.13146.13
    Teflon tubing.7mm id,1.6mm od,5m
    55062-2418 不锈钢接头205.001205.00
    1/16" Fittings and Ferrules 10/PK
    601018-22707 过滤白头,5/43.42143.42
    PTFE Frits 5PK
    73150-0944 制备型溶剂入口过滤头67.73167.73
    Glass filter, solvent inlet, 40um
    82140-0813 长寿命氘灯1,323.7511,323.75
    Deut. lamp, 1100/1200DAD/MWD lnglife-A
    95182-0714 旋口样品瓶,100/28.21128.21
    Screw cap vials, clear 100/PK
    105182-0728螺纹口样品瓶盖,100/15.04115.04
    Blue screw caps 100/PK
    115182-0731 螺纹口样品瓶垫,100/20.29120.29
    Septa, PTFE/red silicone, 8.7mm 100/pk
    Total List Price:US$ 124,959.03
    Freight & Insurance:US$ 6,247.95
    Total Net Price:US$ 131,206.98
  • huaibeijiayuan
    第2楼2013/03/30
    这里的耗材都是必须的,不但不能减,有的有必要增加,前提是不增加增体费用(要求赠送)。
  • richies
    第3楼2013/03/31
    看到了这么清晰报价,基本上可以这样说,LZ还价的空间很小了
  • 张耗材
    第4楼2013/04/01
    还算合理吧,但是应该能再优惠点,我邮箱,有事可以互相交流下
  • 秋醉虞阳
    第5楼2013/04/07
    这个应该还可以优惠
  • richies
    第6楼2013/04/08
    都拿到A的标准报价了,肯定被人入了FUNNEL了,还怎么谈
    秋醉虞阳(wangjianhua1102) 发表:这个应该还可以优惠
  • hza123
    第7楼2013/04/08
    肯定还有得优惠的,报价一般都水。
  • 秋醉虞阳
    第8楼2013/04/09
    拿岛津的比价
    richies(richies) 发表:都拿到A的标准报价了,肯定被人入了FUNNEL了,还怎么谈
  • richies
    第9楼2013/04/09
    你准备陪标去?
    秋醉虞阳(wangjianhua1102) 发表:拿岛津的比价
  • 秋醉虞阳
    第10楼2013/04/09
    不陪标。不是俺的,俺不管
    richies(richies) 发表:你准备陪标去?
