大型高低温冲击试验箱操作分为五部走:预处理、初始检测、试验、恢复、最后检测。下面恒泰丰科和大家一起分享一下详细流程内容:
1.预处理:将被测样品放置在正常的试验大气条件下,直至达到温度稳定。
2.初始检测:将被测样品与标准要求对照,符合要求后直接放入高低温冲击试验箱内即可。
3.大型高低温冲击试验箱试验:
1)试验样品应按标准要求放置在试验箱内,并将试验箱(室)内温度升到指定点,保持一定的时间至试验样品达到温度稳定,以时间长都为准。
2)高温阶段结束后,在5min内将试验样品转换到已调节到-55℃的低温试验箱(室)内,保持1h或者直至试验样品达到温度稳定,以时间长都为准。
3)低温阶段结束后,在5min内将试验样品转换到已调节到70℃的高温试验箱(室)内,保持1h或者直至试验样品达到温度稳定,以时间长都为准。
4)重复上述实验方法,以完成三个循环周期。根据样件大小与空间大小,时间可能会略有误差。
4. 恢复:试验样品从试验箱内取出后,应在正常的试验大气条件下进行恢复,直至试验样品达到温度稳定。
5.大型高低温冲击试验箱最后检测:对照标准中的受损程度及其它方法进行检测结果评定。
孚光精仪
第3楼2017/08/04
MICROSCOPES
Request a Quote
The microscope allows for the precision optical alignment of the probes to the circuit patterns and small area test points.
The following Olympus microscopes can be ordered directly from the www.olympusamerica.comwebsite. Or, we can order them for you. Click on the Request a Quote button and specify the microscope you like us to quote and submit the request.
The following microscope model selections are recommended to use with our probe stations:
• SZ-6145 6.7X - 45X magnification, 10X eyepieces, stand with weighted base, focusing arm, light source, ring light.
• SZ-ZB7 16X - 112X magnification, 10X eyepieces, stand with weighted base, focusing arm, light source, ring light.
• SZ-6145 19X - 135X magnification, 15X eyepieces, auxiliary objective lens, stand with weighted base, focusing arm, light source, ring light.
CUSTOM ACCESSORIES DESIGN
AND BUILD
Request a Quote
From high frequency custom connectors or custom test fixtures to modifications of other products we sell, we have the expertise to help you get to where your project needs to go. Typical custom projects include connector modification for production solutions, probe station customer specific accessories, and more.
CABLE ASSEMBLY
Connect from your instrument to the probe station.
D-coax offers several varieties of high performance Flexible and Semi-rigid assemblies up to 65GHz.
Cable Builder
MICROSCOPE STANDS
Request a Quote
Microscope stands are used to secure the microscope in the desired lication.
The following stands can be ordered directly from the www.spotimaging.com website. Or, we can order them for you. Click on the Request a Quote button and specify the microscope stand you would like us to quote and submit the request.
The following microscope stands selections are recommended to use with our probe stations:
http://www.felles.cn/Upload/20161204074311zEIR.jpg
• SMS16A
Boom Stand with 15.75"
Vertical Post & Weighted Base
• SMS15A
Vertical Post & Table Clamp
VACUUM PUMP
Request a Quote
Vacuum pump is used to hold wafers, PCB’s or other DUT’s to the chuck so the DUT doesn’t shift during the test.
The following Gast pumps can be ordered directly from the www.gastmfg.com website. Or, we can order them for you. Click on the Request a Quote button and specify the pump you like us to quote and submit the request.
The following pump model is recommended to use with our probe stations:
• DOA-P701-AA 115 Volts, 60 Hz, single phase, vacuum up to 29 in. Hg (31 mbar)
http://www.felles.cn/tanzhentai/d14.html点击打开链接
