结构分析与解析 晶体结构测定软件包 (zaoscail.exe) 一套包含了以下全部解结构程序的程序包,ABSEN, GETSPG, GENINS, SHELXS-86, SHELXS-97, SHELXL-97-2,ORTEX, CIFTAB, RASTEP and RENDER, FORMATS, Powdis, PowutlCiftab and Psicalc.非常超值。 wcromer.zip 计算散射因子 zthma32.zip 热振动分析 laue.zip 根据HKL确定空间群 setup-beta1-dec00.exe 自动晶体结构测定及分析软件 (很好用) crystals-b1166a-aug01-setup.exe 自动晶体结构测定及分析软件 (2001.8月版) iso.zip 空间群查找 shelex93.zip 晶体结构精修程序 shelex97.zip 晶体结构分析程序(dos和windows版含原代码、示例和详细使用手册) dhkl.zip 计算调制结构的D值和衍射指标(有原代码) Cizip.zip CrystInfo 1.0是一个Windows应用程序,用来快速、容易地构建、观察与检查晶体结构。晶体的任何参数可以随意调整,并可以改变晶体自身的空间群体与单位晶格的参数。 caos.zip 晶体结构测定操作系统 dirdif99.zip WINDOWS版的解结构程序,DIRDIF for Windows is a set of MS-Windows programs for solving crystal structures. Major features are the use of Patterson methods, and special direct methods for solving symmetry problems. Powerful procedures are provided for the use of chemical knowledge to solve difficult structures. Ab-initio direct methods and structure refinement are not included in the DIRDIF package. cif2sx.zip 数据转换 Program CIF2SX will take as input a legal CIF file and output a legal SHELXL93 instruction file. wgx_164.zip WinGX 结构分析程序 is a MS-Windows system of programs for solving, refining and analysing single crystal X-ray diffraction data for small molecules. It provides a consistent and user-friendly GUI for some of the best publically available crystallographic programs, and has interfaces to other popular programs such as SHELXL-97 and SIR-97. PLATON 和SHELX97一样的晶体结构分析工具。is a versatile SHELX97 compatible crystallographic tool implementing。 It is a versatile crystallographic tool implementing a large variety of standard geometrical calculations (i.e. bonds, angles, torsions, planes, rings, inter-molecular contacts (H-Bond analysis), Coordination etc), tests (i.e. for missing symmetry, voids in the lattice etc.), utilities (cell transformation, SHELXL input etc.), graphics (e.g automatic labelled 'ORTEP-lookalike plots and the molecular graphics program PLUTON) and several filters (e.g. the DIFABS technique for empirical absorption correction (Walker & Stuart), pwt.zip PLATON 的 WINDOWS TASKBAR structures by a Rietveld-type refinement of the atomic coordinates and cell parameters taken from a starting crystalline model. pc-gsas.exe gsas 单晶、粉末解结构软件界面 gsaskit.exe gsas 工具 axesw23.exe AXE 单晶结构软件 espoir.zip Monte Carlo structure solution from powder diffraction software(含原代码) fprime.zip 计算散射因子Calculation of Dispersion Factors (含原代码) class.zip RIETVELD 晶体结构精修程序 Volcal.zip 多面体体积和扭曲参数计算程序 calvalen.zip 结构多面体计算 Diffuse-4.1b-win32.exe hklextin.zip IkaGus_02.exe ster1_12.zip 分子键计算 TOPOSdemo.exe 晶体结构分析程序(demo) GOPENMOL 显示并分析分子结构及其特性,计算分子轨道、电子势的软件包,支持 多种分子结构格式, TINKER 为DOS下的分子设计建模软件,可使用许多常用参数集, PWQikCIF.exe CIF查询软件 zmoilin.exe 分子构建与观察软件,是Tinker软件的Windows界面程序 dtmm4setup.exe 是一个简单易用的3维分子模型显示、编辑与构建程序,可以以各种模式显示3维分子,并能进行编辑。本版本为时间限制版。 gopenmol.win32.1.4.zip 一个显示并分析分子结构及其特性,计算分子轨道、电子势的软件包 绘图类 ATOMS atoms 晶体结构绘图软件 raswin94.zip 绘晶体结构图的原代码,晶体结构绘图,分子3D微观立体结构的软件,可以旋转,以多个模式观看,并可以存成普通图形文件。 晶体绘制F35.ZIP 绘制晶体图(f35_eng.exe f35_doc.exe) icmlited.exe 3维分子浏览工具,是MolSoft公司出品的软件ICM的简化版, 但功能十分强大。 cosmoplayer21.zip 用WEB显示3D图的插件(VRML插件) 3D-CRYSTALS.ZIP 3D图形库(vrml)及说明 shdem60.exe 晶体绘图 crysconI.exe 用原子坐标画粉末图 vmd16.exe 分子绘图 (原代码 vmd16sr.zip vmd-1.6.src.tar.gz) acdcs10.exe 二维分子结构绘图程序。... PWCgraph.exe Crystallographica 根据原子坐标绘晶体图、粉末图等,并对其间的关系进行分析(PASCL方式输入)(Name: Team UCF S/n: 1234567890 Licenses: 9999 Normal: TRWAAHYHHJIR,此注册信息似乎有问题) PWExPack.exe Crystallographica服务包 STRUPLO 晶体结构绘图 for Windows (v 1.0) Ortep-3 绘热振动椭圆图 DTMM40 是一个简单易用的(有机)3维分子模型显示、编辑与构建程序,可以以各种模式显示3维分子。 dm2demo.exe 绘晶体结构图的DEMO d版 DRAWv24.zip 用晶体结构数据(ATOM文件)生产POV和 VRML文件(含原代码) ch20w32.exe IE与NetScape浏览器插件,安装后,可以直接用浏览器观看PDB格式的文件,直接在浏览器中观看3D分子。 WLViewerLite35.exe 3维分子浏览工具,是分子模拟公司出品的软件Weblab ViewPro的简化版,可读取PDB格式及其他数种格式的分子文件。 java3d-1_2-win.exe 使用JAVA技术编写的三维分子查看器,需要安装Java3D,2.1M,后才能执行,此版本使用浏览器执行 Xj3D-min.exe java 3D插件 m2m34dem.exe 主要用来进行各种分子文件的转换,支持30种主要分子格式,也可以用来进行3维分子的简单显示。可将PDB格式输出为POV格式后,用POV-RAY进行渲染,生成非常漂亮的三维图形。演示版只支持样板文件与原子数小于20的分子文件格式的转换。 Mage_5_75.exe 读取并演示Kinemage格式文件的软件。Kinemage格式是一种图像交互式演示格式 MP2install.exe MolPOV是PDB格式至POV格式转化工具,可以将大分子PDB格式文件转化为POV格式
