Pump Unit 泵单元 | |
228-45001-38 | $$lc-20AT Solvent Delivery Unit送液泵 | 2 | set |
228-45018-46 | DGU-20A3R Degassing Unit 脱气单元 | 1 | set |
228-45093-93 | Mixer SUS 20A 混合器 | 1 | set |
Sample Injector进样器 | |
228-45006-38 | SIL-20A Autosampler 自动进样器 | 1 | set |
228-15652-92 | Sample vial, 1.5mL,100pcs/set 样品瓶(注2) | 2 | pc |
228-45041-91 | Reservoir Tray 贮液瓶托盘 | 1 | set |
228-38583-91 | SCHOTT Reservoir bottle流动相瓶(1000ml,5个) | 1 | pkg |
038-02031-06 | SCHOTT Reservoir bottle Cap 流动相瓶盖(1个) | 5 | pcs |
Column Oven柱温箱 | |
228-45009-38 | CTO-20A Column Oven 色谱柱恒温箱 | 1 | set |
Detector检测器 | |
228-45003-38 | SPD-20A UV-VIS Detector 高灵敏度紫外可见光可变波长检测器 | 1 | set |
System Controller系统控制器 | |
228-45011-38 | CBM-20Alite System Controller 网络化系统控制器(注2) | 1 | set |
Packed Columns色谱柱 | |
5020-07345 | InertSustain C18 5um 4.6 x 150mm,色谱柱 | 1 | pc |
5020-07346 | InertSustain C18 5um 4.6 x 250mm,色谱柱 | 1 | pc |
5020-19049 | InertSustain C18 5um 2 CARTRIDGES, 4.0mm I.D.(2pcs/pkg),保护柱柱芯(2/包) | 1 | pc |
5020-08500 | Guard Column HOLDER for 10mm length ,保护柱柱套(4.0mmI.D柱) | 1 | pc |
Workststion工作站 | |
S465-06266-91 | LabSolutions $$lc Workstation Ver.5 Single $$lc(中文版)(注1) | 1 | pc |
