Create or Load the method that you want to calibrate.
Click on Connect on the Action menu to connect to the spectrometer if you are not already connected.
Click on Calibrate Method on the Action menu.
If the method defines analysis parameters for more than one element, the Elements to Calibrate dialogue box will be displayed. Click on the element(s) for which you want to calibrate the method to select them, then click on OK. The calibration action will now be carried out.
Open the Method Dialogue box, and click Save on the General page. The calibrations will be stored with the method. The stored calibration will be used when the method is next run provided Use Stored Calibration is selected on the Calibration Method propertypage.
