ufonmr
第3楼2013/07/19
PULPROG zg2h
NUC1 2H (BF1 is set by topspin: ~BF(1H)*gamma(2H)/gamma(1H) plus some isotope offset between TMS and TMS-d12)
press default to set the right RF routing!
O1P 0 ppm (SFO1 is calculated by topspin: BF1*(1+O1P/1000000))
SW 100 ppm
LOCNUC off
getprosol
(atma is not required for 2H, since it uses the lock channel)
zg
studyen
第5楼2013/07/24
谢谢!
