shirleylei
第2楼2013/11/12
多抽几天也没用,还是老样子。
诊断显示RFDC check fail. Q1 differential voltage actual and its linear fit is not within the maximum deviation. Q1
differential voltage control and its linear fit is not within the maximum deviation. Q1 differential
voltage actual and its linear fit is not within the maximum deviation. Q1 differential voltage control
and its linear fit is not within the maximum deviation. Q1 differential voltage actual and its linear fit is not within the maximum deviation. Q1Voltage: Differential voltage readback is not flat.
Q1Voltage: Differential voltage readback is not flat. Q1Voltage: Differential voltage readback is
not flat. Q1Voltage: Differential voltage readback is not flat. Q1Voltage: Differential voltage
readback is not flat. Q1Voltage: Differential voltage readback is not flat. Q1Voltage: Differential
不知道是不是线路板问题,实在头疼啊
