才哥
第5楼2008/10/06
看来对于陌生的名词,大家都不太愿意去动用搜索引擎,而是喜欢根据自己已知的知识来推断。呵呵
关于RoHS-5和RoHS-6,这确实是个很民间很不正式的说法,之前应该是起源于某些大公司的管控文件,后来大家就都这么说,但是现在基本上没人这么说了。这里给大家介绍一下:
RoHS6,是指该材料中,RoHS管制的6种有害物质全部都符合要求(低于限量)。
RoHS5,是指该材料中,铅含量高于1000ppm但是符合豁免条款,除铅以外的其他5种有害物质都符合要求(低于限量)。
minminrose
第6楼2008/10/30
RoHS-5
Product does not contain Cadmium (Cd), Mercury (Hg), Hexavalent Chromium (Hex-Cr), Polybrominated Biphenyls (PBB), Polybrominated Diphenyl Ethers(PBDE )Product contains Lead in applications considered as solders including plating finish for component terminations, solder paste, solder balls, solder bumps, PCB finish, and solder columns
Maximum reflow temperature is 235°C
RoHS-6
Product does not contain Cadmium (Cd), Mercury (Hg), Hexavalent Chromium (Hex-Cr), Polybrominated Biphenyls (PBB), Polybrominated Diphenyl Ethers (PBDE) Some internal connections may contain Lead used in high melting temperature solder (solder alloys containing more than 85% Lead Plating finish on component terminations is Lead-free.
Maximum reflow temperature is 245°C.
详见 http://forum.eetchina.com/FORUM_TOPIC_POST_1200024493_0.HTM
如果说根据这个的话,楼上的说法是正确的!
