gcMS分析一款进口护手霜的香气化合物
symmacros
第1楼2013/12/28
2 结果与讨论
2.1 实验结果
用固相微萃取处理油脂样品,简单方便,灵敏度高,有利于香气化合物的提取。
固相微萃取的萃取头在进样口自动经过解析后,进入GC进行分离。用一根毛细管通过分流器分流后分别进入MSD和FID。这样一次同时得到总离子色谱图TIC和FID色谱图两个结果,方便定性和定量。即用GC-MS的TIC定性,GC-FID定量。同时得到TIC和FID的色谱图(见图1 TIC)。
在前面有部分一堆连峰,是一些来至基质的烷烃化合物的干扰,里面也有少量香气化合物,可以利用Amdis来找出了。
图1 进口护手霜香气的总离子色谱图(TIC)
表进口护手霜的香气成分表
No. |
| Name 名称 |
1 | 3.587 | ETHYL ACETATE | 0.003 | ||
2 | 3.748 | BUTANONE, 2- | 0.002 | ||
3 | 4.252 | ALCOHOL | 1.501 | ||
4 | 5.89 | PINENE, ALPHA- | 0.019 | ||
5 | 5.89 | THUJENE, ALPHA- | 0.008 | ||
6 | 8.589 | SABINENE | 0.354 | ||
7 | 10.244 | MYRCENE | 0.274 | ||
8 | 11.447 | LIMONENE | 1.224 | ||
9 | 11.715 | PHELLANDRENE BETA | 0.742 | ||
10 | 12.982 | OCIMENE Z-BETA | 1.155 | ||
11 | 13.282 | TERPINENE, GAMMA- | 0.352 | ||
12 | 13.627 | OCIMENE E-BETA | 1.509 | ||
13 | 13.973 | CYMENE, P- | 1.838 | ||
14 | 14.766 | TERPINOLENE | 0.281 | ||
15 | 21.103 | CRESYL METHYL ETHER, P- | 0.776 | ||
16 | 22.376 | ACETIC ACID | 0.116 | ||
17 | 24.435 | BENZALDEHYDE | 0.226 | ||
18 | 24.636 | LINALYL ACETATE, 1,2-DIHYDRO- | 0.074 | ||
19 | 24.913 | CYCLOPENTANOL, 3-ISOPROPENYL-1-ME-2-METHYLEN- | 0.049 | ||
20 | 25.091 | DIHYDRO LINALOOL | 0.056 | ||
21 | 25.221 | LINALYL ACETATE, ALPHA- | 0.068 | ||
22 | 25.703 | LINALOOL | 2.094 | ||
23 | 26.015 | LINALYL ACETATE | 1.890 | ||
24 | 27.263 | CARYOPHYLLENE | 0.009 | ||
25 | 27.465 | PROPYLENE GLYCOL, 1,2- | 0.071 | ||
26 | 28.261 | METHYL BENZOATE | 0.076 | ||
27 | 28.417 | ACETYLPYRAZINE-2 | 0.015 | ||
28 | 29.083 | ETHYL CAPRINATE | 0.006 | ||
29 | 29.253 | JASMYLONE P. 2 | 0.006 | ||
30 | 29.929 | CITRONELLYL ACETATE | 0.006 | ||
31 | 30.015 | DIHYDRO CITRONELLOL | 0.042 | ||
32 | 30.277 | MENTHADIEN-4-YL ACETATE, 1,8-P- | 0.008 | ||
33 | 31.183 | TERPINEOL, ALPHA- | 0.266 | ||
34 | 32.341 | NERYL ACETATE | 0.068 | ||
35 | 32.341 | BENZYL ACETATE | 0.703 | ||
36 | 33.152 | FARNESENE, 3E,6E-ALPHA- | 0.006 | ||
37 | 33.4 | CADINENE, DELTA | 0.002 | ||
38 | 33.4 | GERANYL ACETATE | 0.139 | ||
39 | 33.517 | CITRONELLOL, ALPHA- | 0.023 | ||
40 | 33.85 | CITRONELLOL | 0.909 | ||
41 | 34.085 | unknown | 0.059 | ||
42 | 34.412 | DAMASCONE, TRANS-DELTA- 2 | 0.000 | ||
43 | 34.622 | BENZYL PROPIONATE | 0.022 | ||
44 | 34.988 | NEROL | 0.258 | ||
45 | 35.374 | PHENYLETHYL ACETATE, 2- | 0.034 | ||
46 | 35.686 | ANETHOLE TRANS- | 0.005 | ||
47 | 36.128 | DIPROPYLENE GLYCOL | 0.011 | ||
48 | 36.248 | BENZALDEHYDE, 4-TERT.-BUTYL- | 0.006 | ||
49 | 36.493 | IRALDEIN, GAMMA- | 1.156 | ||
50 | 36.493 | IONONE, ALPHA- | 0.173 | ||
51 | 36.65 | GERANIOL | 0.213 | ||
52 | 37.145 | IRALDEIN, DELTA- | 0.087 | ||
53 | 37.634 | BENZYLALCOHOL | 1.977 | ||
54 | 38.103 | DIPROPYLENE GLYCOL | 0.020 | ||
55 | 38.743 | IRALDEIN, ALPHA- | 0.175 | ||
56 | 38.743 | PHENYLETHYL ALCOHOL, 2- | 1.246 | ||
57 | 38.743 | BHT IONOL | 0.037 | ||
58 | 39.422 | IONONE, BETA- | 0.019 | ||
59 | 39.886 | unknown | 0.012 | ||
60 | 40.438 | ALLYL SALICYLATE | 0.014 | ||
61 | 40.593 | unknown | 0.020 | ||
62 | 40.717 | ALCOHOL C 12 | 0.066 | ||
63 | 40.929 | CYCLAMEN ALDEHYDE | 0.057 | ||
64 | 40.929 | BIPHENYL | 0.005 | ||
65 | 41.551 | IRALDEIN, BETA- | 0.037 | ||
66 | 41.756 | NEROLIDOL, CIS- | 0.008 | ||
67 | 41.976 | BENZYL METHYL KETONE, 4-TERT.-BUTYL- | 0.073 | ||
68 | 42.096 | PHENOL | 0.025 | ||
69 | 42.252 | ANISYL ALDEHYDE | 0.782 | ||
70 | 42.946 | LILIAL | 1.227 | ||
71 | 42.946 | ISOPROPYL MYRISTATE | 0.048 | ||
72 | 43.289 | ISO E SUPER | 0.337 | ||
73 | 43.87 | CAPRYLIC ACID | 0.053 | ||
74 | 43.87 | ISO E SUPER | 0.116 | ||
75 | 43.87 | BOURGEONAL | 0.032 | ||
76 | 44.116 | STYRATE (EMERY) | 0.031 | ||
77 | 44.477 | CRESOL, P- | 0.009 | ||
78 | 44.624 | PHENOXY ETHYL ACETATE | 0.049 | ||
79 | 45.007 | ISO E SUPER | 0.023 | ||
80 | 45.414 | ISO E SUPER | 0.057 | ||
81 | 46.476 | PHENOXYETHYL ALCOHOL | 58.668 | ||
82 | 46.86 | Dehydroacetic Acid | 1.737 | ||
83 | 47.22 | TETRADECANOL | 1.844 | ||
84 | 47.95 | ROS ACETATE | 0.048 | ||
85 | 48.519 | HELIOTROPIN | 0.454 | ||
86 | 48.665 | Galaxolide | 0.017 | ||
87 | 48.868 | Galaxolide | 0.014 | ||
88 | 48.995 | Galaxolide | 0.011 | ||
89 | 49.393 | GAMMA UNDECALACTONE | 0.025 | ||
90 | 49.576 | ETHYL PALMITATE | 0.002 | ||
91 | 49.576 | HEDIONE | 0.015 | ||
92 | 49.838 | HEDIONE | 0.019 | ||
93 | 50.197 | HEDIONE, TRANS- | 1.196 | ||
94 | 50.197 | CAPRIC ACID | 0.011 | ||
95 | 50.995 | GALAXOLIDE | 0.201 | ||
96 | 51.198 | GALAXOLIDE | 0.170 | ||
97 | 51.384 | SANDEL | 0.034 | ||
98 | 51.498 | HEDIONE, CIS- | 0.073 | ||
99 | 51.849 | SANDEL | 0.023 | ||
100 | 52.074 | ISOEUGENOL E | 0.012 | ||
101 | 52.246 | HEXYLCINNAMIC ALDEHYDE, ALPHA | 0.352 | ||
102 | 52.465 | CHROMANOLIDE P.3 | 0.022 | ||
103 | 52.617 | DIETHYL PHTHALATE | 0.805 | ||
104 | 52.617 | HEDIONE, CIS- | 0.002 | ||
105 | 52.984 | SANDEL | 0.028 | ||
106 | 53.175 | HEXADECANOL | 1.400 | ||
107 | 53.175 | CHROMANOLIDE | 0.003 | ||
108 | 53.435 | SANDEL | 0.060 | ||
109 | 53.803 | HYDROQUINONE MONOMETHYL ETHER | 0.091 | ||
110 | 54.001 | CHROMANOLIDE | 0.032 | ||
111 | 54.167 | SANDEL | 0.028 | ||
112 | 54.334 | HEDIONE | 0.014 | ||
113 | 54.6 | COUMARIN | 3.199 | ||
114 | 54.6 | BENZOIC ACID | 2.238 | ||
115 | 55.094 | SANDEL | 0.053 | ||
116 | 55.215 | LYRAL | 0.083 | ||
117 | 55.364 | BENZOPHENONE | 0.074 | ||
118 | 55.54 | LYRAL | 0.144 | ||
119 | 56.101 | SANDEL | 0.029 | ||
120 | 56.101 | LAURIC ACID | 0.074 | ||
121 | 56.487 | SANDEL | 0.017 | ||
122 | 56.773 | ETHYLVANILLIN | 0.005 | ||
123 | 57.208 | DIISOBUTYL PHTHALATE | 0.009 | ||
124 | 57.88 | VANILLIN | 0.124 | ||
125 | 58.63 | OCTADECANOL | 0.487 | ||
126 | 59.35 | BENZYL BENZOATE | 0.456 | ||
127 | 59.654 | PHENYLPROPANOIC ACID | 0.022 | ||
128 | 62.432 | ETHYLENE BRASSYLATE | 0.025 | ||
129 | 63.198 | BENZYL SALICYLATE | 0.006 | ||
100.00 |
