xfuzengh
第3楼2014/03/13
我们也有参加,关于以下要求如何理解,是要求直接将两个整块按送样状态测试而不是按标准切碎为不大于6mm*6mm吗:
Important information
1) Ensure the entire piece of material supplied is taken for analysis.
2) Calculations for analysis are to be on a sample mass of 0.1g.
3) When performing the final calculations 0.1g must be used as the mass of material taken.
4) DO NOT perform any calculations based upon the actual weight of material supplied..
fang130
第4楼2014/03/13
我们的理解是整个样品,全部剪掉测试,结果按0.1g来计算。我们样品量是0.12g,你收到的样品有多少克?
