扩展名------ 类型 --------------------------------------------详细解释 MIO--Manual ICS Dialogue File ---------------Terminal Mode commands used for QA facilities MSK--Database-------------------------------- Instrument alarms and modification reasons. MVR--MVR save state File--------------------- All data saved resulting from Regression computations. PRG--Analytical program Files-----------------Global Analytical Data for Analysis QUA--Quality File-----------------------------All data related to Quality used for Quality check. RXB--Reception Buffering File-----------------This contains data received from device i.e.EXAN. S1--Main database File-------------------------Contains instrument configuration,analytical conditions setting-up samples,... S2--Main database File------------------- -----Contains instrument configuration,analytical conditions setting-up samples,... SEL--Material selection file--------------------Global data using Material used for change correction SRC--Import/Export Raw--------------------------Error Massage,Data File Alarm,etc.Used for Database Generator,These Files may be copied and then imported into the Database. (continue)
