【求助】岛津GC-17工作站须用英文windows 95系统,无法安装,请问谁能提供?
  • chdongdong
    2006/09/11
气相色谱(GC)
  • 安装英文windows时,系统提示:this version of microsoft scandisk will work only with ms-dos versions 5.5 and later.setup found a commressed volume or a disk-cache utility on your computer,quit setup and check your compressed volume with your disk compression software or remove the disk-cache utility,then run setup again.如何解决?谁能提供英文windows系统?急急急!!!!!!
  • kencnjp
    第2楼2006/09/12
    WINDOES95要在DOS5.5环境下安装的呢
