daxu
第3楼2015/03/25
Powder data statistics Fitted -Bknd pFree Average
Bank Ndata Sum(w*d**2) wRp Rp wRp Rp wRp Rp Npfree DWd Integral
Hstgm 1 PXC 1 2693 6738.9 0.0818 0.0640 0.0835 0.0648 0.0000 0.0000 0 0.912 0.870
Powder totals 2693 6738.9 0.0818 0.0640 0.0835 0.0648 0.0000 0.0000 0 0.912
No serial correlation in fit at 90% confidence for 1.897 < DWd < 2.103
Cycle 86 There were 2693 observations.
Total before-cycle CHI**2 (offset/sig) = 6.7389E+03 ( 5.5705E+01)
Reduced CHI**2 = 2.525 for 24 variables
Reflection data statistics
Histogram 1 Type PXC Nobs = 1418 R(F**2) = 0.0866
After matrix normalization and Marquardt modification:
Full matrix recip. condition value & -log10 = 0.4196E-02 2.38
The value of the determinant is 2.1073*10.0**( -5)
Atom parameters for phase no. 1
frac x y z 100*Uiso 100*U11 100*U22 100*U33 100*U12 100*U13 100*U23
Calculated unit cell formula weight: 971.936, density: 3.743gm/cm**3
Atom parameters for phase no. 2
Calculated unit cell formula weight: 688.968, density: 3.297gm/cm**3
Atom parameters for phase no. 3
Calculated unit cell formula weight: 6484.752, density: 3.029gm/cm**3
Atom parameters for phase no. 4
Calculated unit cell formula weight: 1369.926, density: 3.142gm/cm**3
Phase/element fractions for phase no. 1
Hist Elem: 1 1 PXC
Fraction : 1.32946
Sigmas : 0.451838E-01
Shift/esd: 0.00
Wt. Frac.: 0.14616
Sigmas : 0.424154E-02
Phase/element fractions for phase no. 2
Hist Elem: 1 1 PXC
Fraction : 4.09246
Sigmas : 0.854866E-01
Shift/esd: -0.01
Wt. Frac.: 0.31894
Sigmas : 0.453743E-02
1cement GENLES Version Win32 Mar 25 17:08:36 2015 Page 11
Phase/element fractions for phase no. 3
Hist Elem: 1 1 PXC
Fraction : 0.839721E-01
Sigmas : 0.296545E-02
Shift/esd: -0.01
Wt. Frac.: 0.61597E-01
Sigmas : 0.204128E-02
Phase/element fractions for phase no. 4
Hist Elem: 1 1 PXC
Fraction : 3.05427
Sigmas : 0.251936E-01
Shift/esd: 0.01
Wt. Frac.: 0.47330
Sigmas : 0.205628E-02
Phase/element fraction sum(shift/error)**2 : 0.00
