BS EN 10225-2009 固定近海结构的可焊接结构钢.交付技术条件
国外标准
  • 【英文标准名称】: Weldable structural steels for fixed offshore structures - Technical delivery conditions
    【原文标准名称】: 固定近海结构的可焊接结构钢.交付技术条件
    【标准号】: BS EN 10225-2009
    【标准状态】: 现行
    【国别】: 英国
    【发布日期】: 2009-07-31
    【实施或试行日期】: 2009-07-31
    【发布单位】: 英国标准学会(GB-BSI)
    【起草单位】: BSI
    【标准类型】: ()
    【标准水平】: ()
    【中文主题词】: 验收规范;化学成分;分类;色码;建筑;定义(术语);交货条件;尺寸规格;精整;空心型材;检验;作标记;材料;机械性能;金属;生产方法;近海建设工程;顺序示度;轮廓;保护层;质量;轧制钢材;抽样方法;薄板材;薄钢板;规范(验收);钢产品;钢;结构钢;表面防护;测试;厚度;可焊性;可焊接的;屈服强度
    【英文主题词】: Acceptance specification;Chemical composition;Classification;Colour codes;Construction;Definitions;Delivery conditions;Dimensions;Finishes;Hollow sections;Inspection;Marking;Materials;Mechanical properties;Metals;Methods of manufacture;Offshore construction works;Order indicationsrofilerotective coat;Quality;Rolled shape;Sampling methods;Sheet materials;Sheet steels;Specification (approval);Steel products;Steels;Structural steels;Surface protection;Testing;Thickness;Weldability;Weldable;Yield strength
    【摘要】: This European Standard specifies requirements for weldable structural steels to be used in the fabrication of fixed offshore structures in the form of plates up to and including 150 mm thick. It also specifies sections up to 63 mm thick except for sections delivered in the as-rolled condition which are permitted up to 25 mm thick only. Seamlesshollow sections up to and including 40 mm thick and high frequency electric resistance welded hollow sections up to and including 20 mm thick are specified. Greater thicknesses for sections and hollow sections may be agreed,provided the technical requirements of this European Standard are maintained.For plates the thickness limitations are:S355G2+N, S355G5+M, - up to and including 20 mmS355G3+N, S355G6+M - up to and including 40 mmS355G7+N, S355G8+N, S355G9+N, S355G10+N - up to and including 150 mmS355G7+M, S355G8+M, S355G9+M, S355G10+M - up to and including 100 mmS420G1+QT, S420G1+M, S420G2+QT, S420G2+M - up to and including 100 mmS460G1+QT, S460G1+M, S460G2+QT, S460G2+M - up to and including 100 mmThe standard is applicable to steels for offshore structures, designed to operate in the offshore sector but not to steels supplied for the fabrication of subsea pipelines, risers, process equipment, process piping, and other utilities. It is primarily applicable to the North Sea Sector, but may also be applicable in other areas provided thatdue consideration is given to local conditions e.g. temperature.In the case of hollow sections formed from plate with the seam fusion welded, this European standard covers only the requirements of the plate material.Minimum yield strengths up to 460 MPa are specified together with low temperature impact properties attemperatures down to –40 °C.This European standard applies to material supplied ex-mill or from merchant's stock.
    【中国标准分类号】: H40
    【国际标准分类号】: 77_140_10
    【页数】: 80P.;A4
    【正文语种】: 英语
  • 该帖子已被管理者-穿越时空设置为精华,下面是奖励记录:加2积分,加5声望
  • 该帖子已被版主-穿越时空加2积分,加2经验;加分理由:鼓励分享
  • 穿越时空
    第1楼2015/02/28
    分享就奖励一下。
