表1-1 不同浓度黄芩提取液的密度(20°C) (g/cm3)
Table 1-1 The density of Scutellariae Radix extracts(20°C) (g/cm3)
浓度C / g·mL-1 | 黄芩水提液 | 黄芩醇提液 |
0 | 0.9982 | 0.9094 |
0.2 | 1.0415 | 0.9405 |
0.4 | 1.0695 | 0.9815 |
0.6 | 1.0990 | 1.0170 |
0.8 | 1.1345 | 1.0560 |
1.0 | 1.1580 | 1.0905 |
表2不同温度下不同浓度黄芩水提液的黏度(mPa·s)
Table 2 The viscosity of Scutellariae Radix water extracts(mPa·s)
温度T /°C | 浓度C / g·mL-1 | |||||
水 | 0.2 | 0.4 | 0.6 | 0.8 | 1.0 | |
20 | 1.01 | 2.96 | 7.39 | 20.1 | 56.0 | 124.7 |
25 | 0.89 | 2.72 | 6.49 | 17.1 | 47.8 | 106.3 |
30 | 0.80 | 2.38 | 5.62 | 14.7 | 40.2 | 91.6 |
35 | 0.72 | 2.09 | 4.97 | 12.9 | 35.9 | 77.3 |
40 | 0.66 | 1.86 | 4.44 | 11.4 | 31.1 | 67.6 |
45 | 0.6 | 1.68 | 3.95 | 9.90 | 27.9 | 58.7 |
50 | 0.55 | 1.55 | 3.61 | 8.74 | 23.3 | 51.7 |
55 | 0.51 | 1.39 | 3.34 | 8.23 | 21.3 | 45.4 |
60 | 0.47 | 1.27 | 2.98 | 7.36 | 19.2 | 41.5 |
65 | 0.44 | 1.18 | 2.73 | 6.57 | 16.8 | 36.5 |
70 | 0.41 | 1.12 | 2.32 | 5.28 | 14.2 | 32.4 |
75 | 0.38 | 1.03 | 2.00 | 4.64 | 12.8 | 30.1 |
表3 不同温度下不同浓度黄芩醇提液的黏度(mPa·s)
Table 3 The viscosity of Scutellariae Radix ethanol extracts(mPa·s)
20 | 4.22 | 6.32 | 13.1 | 26.1 | 71.3 |
25 | 3.3 | 5.19 | 9.65 | 20.1 | 55.2 |
30 | 2.85 | 4.52 | 7.95 | 16.2 | 43.8 |
35 | 2.55 | 4.02 | 6.72 | 13.2 | 34.5 |
40 | 2.18 | 3.55 | 5.93 | 10.8 | 27.5 |
45 | 2.01 | 2.92 | 5.04 | 9.29 | 20.7 |
50 | 1.78 | 2.56 | 4.16 | 7.59 | 14.8 |
55 | 1.67 | 2.18 | 3.34 | 5.74 | 11.2 |
60 | 1.42 | 1.76 | 2.74 | 4.20 | 6.88 |
65 | 1.27 | 1.55 | 2.25 | 3.25 | 5.14 |
70 | 1.12 | 1.31 | 2.03 | 2.75 | 4.37 |
75 | 1.02 | 1.18 | 1.82 | 2.45 | 3.97 |
