It does not look like Cr2p there. Even you want to believe it is Cr2p but seeing Cr2p3 peak but no Cr2p1 is not making sense.
The Fe2p seems real.
Why are the spectrum so noisy? You need to make more analysis time to make better Signal-to-Noise spectrum in order to judge well.
