changyanxiao
第2楼2016/05/25
有个疑问,到底是所有可接触的部件都要测试呢,还是只测试可被儿童放入口中的物品呢?按本标准来判定有一些可接触的物品不一定能被儿童放入口中吧。原文是这么写的:
7.Shall not be placed on the market or used in articles supplied to the general public, if the concentration of lead (expressed as metal) in those articles or accessible parts thereof is equal to or greater than 0,05 % by weight, and those articles or accessible parts thereof may, during normal or reasonably foreseeable conditions of use, be placed in the mouth by children.
燕飞
第3楼2016/05/31
是指可被儿童放入口中的 (物品及可接触部件)
有些物品体积小能直接放入口中,有些是体积大的物品中的能够放入口中的可接触部件
