仪器点炬成功后,初始化时仪器与电脑连接断开,软件无法控制仪器,仪器在运转,软件提示无法确定氖灯能量!电脑重新启动后也无法与电脑连接成功,重装软件后也是一样。请问各位有没有遇到过这种情况? The plasma generator is not connecting. It is not possible to establish a connection to the plasma generator. Make sure that the plasma generator is powered on and that the cable is connected. Then go to the Plasma page in the Diagnostics window and click on the Reconnect button.
Failed to determine neon energy. This condition may be caused by a problem within the spectrometer or by connection problems between the computer and the spectrometer. Check the following: ?Make sure the cable between the computer and spectrometer is connected. ?Make sure the spectrometer is switched on. If this does not correct the problem a service visit may be required. Before calling service, turn off the power to the spectrometer, wait a few minutes, and turn it back on. Then start the software and try performing analyses. If the problem persists, call service. If the problem goes away, monitor the system and if the problem reappears, call service.
Computer unable to communicate with generator. The computer was unsuccessful in establishing communication with the generator. Possible reasons include: » Cable between computer and spectrometer not connected. » Spectrometer power is not switched on. Correct the problem and then press the Reconnect button on the Generator page of the Diagnostics window.
Establish connection to the device? This procedure attempts to establish communication between the computer and one of the hardware devices. You should do this only if the program was not able to communicate when it first loaded or has lost communication. This could happen, for example, if power to the device was not turned on or the cable was not connected. Click on OK to establish communication with the device or click on Cancel to return to diagnostics.
Failed to connect to Spectrometer. This condition may be caused by a problem within the spectrometer or by connection problems between the computer and the spectrometer. Check the following: ?Make sure the cable between the computer and spectrometer is connected. ?Make sure the spectrometer is switched on. If this does not correct the problem a service visit may be required. Before calling service, turn off the power to the spectrometer, wait a few minutes, and turn it back on. Then start the software and try performing analyses. If the problem persists, call service. If the problem goes away, monitor the system and if the problem reappears, call service.
