bigtiger 2018/12/15
Name Pivaloxcyclene(Pivacylene) CAS Number 068039-44-1
bigtiger
第3楼2018/12/15
peach pivalate | |||
CAS : 68039-44-1 EC : 268-259-4 Odor : fruity peach sweet powdery green floral |
Givaudan |
Pivacyclene Odor: Fruity, Peach, Green Use: Pivacyclene has a dry fruity peach note with a fresh green softness. It works well with the other cyclenes as a modifier around 1% in soaps and detergents. Also ideal for cosmetics and toiletries at 5% or above if fragrance character allows. It is often used in combination with gamma-lactones to soften the fatty aspects. |
p3195261
第4楼2018/12/15
Givaudan |
