不同寻常的Eternity
厂商论坛
  • 不同寻常的Eternity
    Eternity翻译为中文是永恒的意思!Eternity系列色谱柱是kromasil色谱柱的高端系列。Eternity系列的品质更加卓越,当然价格也更加昂贵。Eternity系列是kromasil的专利产品,是一种长寿命的色谱柱!
    Eternity系列的特点是:
    The silca matrix
    The Eternity platform is based on the Kromasil 100A silca matrix,well known for high mechanical stability, and a well-defined pore structure.
    The organosilane interfacial gradient
    The silica matrix is bonded using a patent-pending technology.An organosilane is immobilized on the silica, and, under certain proprietary conditions merged into an organic/inorganic interfacial gradient.The pores are virtually returned to their original size,resulting in a surface exhibiting both organic and inorganic moieties.This process step has been fine-tuned to give Kromasil EternityXT its extreme chemical stability,extending the pH range and packing lifetime.
    The finished product
    Finally the product is functionalized with various surface chemistries ,followed by a proprietary endcapping process.
    这段话原汁原味的表达了Eternity色谱柱的特点,简言之就是,硅胶粒径合理,多孔硅胶的制备使用了专利技术,合理的键合和封端技术。从而延长了pH范围和色谱柱的使用时间。再简言之,就是结构决定性质。色谱柱生产过程中的各个工艺都做的非常精细。色谱柱看似相同,其不同之处在于细微之处的某些专利,有些时候这种专利技术是非常牛气的!
    相比于Classic系列,Eternity的系列种类还是比较少的。我觉得各位想提高色谱柱使用寿命的朋友不妨选择Eternity系列,或许可以解决色谱柱不耐用的难题。如果您有不同的见解与看法,欢迎批评指正!
  • wsy18
    第1楼2019/02/27
    希望用过的版友来谈谈应用体会。
  • 检测老菜鸟
    第2楼2019/03/28
    延长了pH耐受范围挺好的。
