智慧的弟弟
第1楼2007/01/29
色谱柱固定液英汉对照
阿皮松(真空润滑脂).................................................Apeizon-
八(2-羟内基)蔗糖 .............................................Hyprose SP-80
苯磺酸钠乳化剂 ......................................................Otonite-
苯喹啉 .....................................................7.8-Benzoquinoline
苯乙腈 ..........................................................Bebzylcyanide
苄基联苯 .......................................................Benzyldiphenyl
丙烷壬酸 三甲酯(纤烷丝酯)............................... Celanese Ester No.9
NN-一,二(2氰乙基)甲酰胺 ...............N,N-Bis-(2cyanoethyl)formamide(BCEF)
N,N-一,二甲基硬脂酸酰胺(混以十四十六烷碱) .......................Hallcomiol
M- 二甲基双十八烷基皂士 ...........................................Bentone34
癸二腈 .......................................................Sebaconitrile
癸二酸 二(2-乙氧基乙)酯 ...................Bis-(2-ethoxyethyl)Sebacate.BEES
癸二酸二辛酯.......................................... Dioctyl Sebacate(DOS)
环氧树脂................................................................EPON-
已二酸二(2-甲氧基乙)酯 ....................Bis-(2-moethoxyethyl)adipate(bmea)
已二酸二(2-乙氧基乙)酯 ....................Bis-(2-moethoxyethyl)adipate(bmea)
甲基硅氧烷与聚乙醇丁二酸共聚物 ........................................ECSS-X
甲基三氧苯基(10%)硅氧烷 .......................................Versilube F-50
甲基硅油(甲基硅氧烷) .....................................................OV-
角鲨烷 ...............................................................Spulane
角鲨烯 ...............................................................Squlane
季戊四醇四氰乙基醚 ..............Tetracyanoethylanted penterythriyriol(tcepe)
聚1,4-丁二醇丁二基酸酯 .......................Butanel,1,4-diol suceinate(BDS)
聚乙烯基吡咯烷酮 ....................................Polyinylpyrrolidone(PVP)
聚苯基二乙醇胺丁二酸酯 .................Phenyldiethanolqnine succinate(PDEAS)
聚苯醚 ........................................................Polyhenylether
聚苯醚砜 .............................................................Poly-S-
聚丙二醇已二酸酯.................................................... Roplex400
聚二乙二醇丁二酸酯 ................Dienthyeneglycol succinate(DECS,LAC-3R-728)
聚二乙二醇已二酸酯 ..................Dienthyeneglycol adipate(DEGA,LAC-1R-296)
聚环已烷二甲醇丁二酸酯 .................Cyclohexanedimetheanolsuccinate(CHDMS)
聚三氟氟乙烯油 ....................................................Kel-FOil#10
聚碳硼烷甲基硅氧烷 ....................................................Dexsil-
聚烷撑二醇 ..............................................................UCON-
聚酰胺 ................................................................Poly-A-
聚新戊二醇丁二酸酯.............................Neeopentyl glyol succinate(NGS)
聚亚酰胺110 ..........................................................Poly-110-
聚乙二醇 ........................................................Carbowax-,PEC-
聚乙二醇20M与2-硝基对苯二甲酸反应物 ...............................EfFAP,OV-351 ..
聚乙二醇20M与对苯二甲酯反应物 ..................................Carbowax20M-TPA
聚乙醇单硬脂酸脂 ...................................................Ethofat60/25
聚乙二醇丁二酸脂 .......................Ethylene glycol succinate(EGS,LAC-4-R866
聚乙二醇已二酸脂 ...................................Ethylene glycol adipate(EGA)
聚乙二醇壬基苯基醚.................................................... Lgepal CO
邻苯二甲酸二三(2-丁氧基乙)酯 .........................Bis(2-butoxyethyl)phthalan
邻苯二甲酸二癸酯 ......................................DI-N-decyl phthalate(DDP)
邻苯二甲酸二壬酯.......................................... Dinonylphthalate(DNP)
邻苯二甲酸二辛酯.......................................... Diocyl phthalate(DOP)
邻苯二甲酸二(2-乙基已)酯 ............................Bis(2-ethylthexyl)phthalate
邻苯二甲酸二异癸酯..................................... Diisodecyl phthalate(DDP)
磷酸邻三甲苯酯 ..............................................Tricresy phosphate.
β,β一硫代二丙腈 ..................................β,β-Thiodipripionitrile(TDPN)
碳油 ............................................................Halocarbon oit-
马来酸二正丁酯 ...........................................Di-n-butyl maleate(DBM)
1-羟基-2十七碳烷基噗唑啉............................................... Amine-220
氰丙基苯基硅氧烷 ..........................................................Silar-
氰乙基甲基硅氧烷与聚乙二醇丁二酸酯共聚物 .................................ECNSSM.
曲拉通 ....................................................................Triton
1、2、3-三(2-氰乙氧基)丙烷 .................1.2.3-Tris-(2-Cyanothoxy)pronane(TGEP)
三氟丙基(50%)甲基硅氧烷 .......................................................QF-
三乙醇胺 ........................................................Triethanolamin.e
山梨糖醇 ................................................................Sorbitol
双甘油 ................................................................Diglycerol
四(2-羟乙基)乙二胺...................... Tetrahydroxyethyl ethylenediamine(THEND)
四乙二醇二甲醚 T ................................eraethylene gycol dimethyl ether
β-β-氧二丙腈 .......................................β,β-Oxydipropionitrile(ODPN)
液体石蜡 ....................................................................Nujo
液晶 ....................................................................BMBTBMBI
有机皂士............................................................ -34Bentone34
正十六烷 ............................................................n-Hexadecath
聚酰胺树脂........................................................... Versamid900
聚新戊二醇已二酸酯.................................. Neeopentyl glyol adipate(NGA)
智慧的弟弟
第2楼2007/01/29
毛细管柱的安装及其维护
1. 毛细管柱的安装
当选择好合适的毛细管柱之后,就应该进行正确地安装工作。先将毛细管柱的两端截取一段(如果是已经使用过的柱子,安装之前一定要分清楚哪个是与进样口相连,哪个是与检测器相连),然后安装,注意螺帽不用拧的太紧。
安装柱子应该在进样口部件都安装好之后。当柱子的一段与进样口接好后,应该通载气,将接检测器的一端放置在丙酮溶液中,观察是否有气泡,用以判断毛细管柱是否被堵。
2. 柱子的老化。
毛细管柱特别是新的柱子,使用之前的老化是很重要的,老化的目的就是使涂层固定相中的低沸点物质挥发干净,使得固定液分配的比较均匀。老化时,毛细管柱的一端接进样口,另一端不接检测器,放置于柱箱内。老化的最高温度应该低于柱子最高使用温度的20~30℃,老化时应该采用程序升温,升温的速率尽量小,然后在最高温度保持4小时左右。第一次老化结束后,将连接检测器的一端的毛细管柱截取一段,安装后查看基线是否正常,若不正常还需要继续老化。
3. 毛细管柱的维护
毛细管柱在平时不使用的时候,因该妥善保管,柱子的两端都应该封好(可用废旧的进样垫),主要是防止固定液被氧化和杂物进入。放置时也应该留意柱子的那一端是连接检测器,哪一端是连接进样口。
不同毛细管柱压力的设置
压力单位(psi)
15m 25m 30m 50m 100m
0.20mm 10-15 20-30 18-30 40-60 80-120
0.25mm 8-12 13-22 15-25 28-45 55-90
0.32mm 5-10 8-15 10-20 16-30 32-60
0.53mm 1-2 2-3 2-4 4-8 6-14
气相色谱分析中柱长、柱内径、柱温、载气流速、固定相、进样等操作条件对分离的影响
1、柱长,柱内径:一般讲,柱管增长,可改善分离能力,短则组分馏出的快些;柱内径小分离效果好,柱内径大处理量大,但柱内径过大,将导致担体不能均匀地分布在色谱柱中。分析用柱管一般内径为3-6毫米,柱长为1-4米。 2、柱温:是一个重要的操作变数,直接影响分离效能和分析速度。选择柱温的根据是混合物的沸点范围,固定液的配比和鉴定器的灵敏度。提高柱温可缩短分析时间;降低柱温可使色谱柱选择性增大,有利于组分的分离和色谱柱稳定性提高,柱寿命延长。一般采用等于或高于数十度于样品的平均沸点的柱温为较合适,对易挥发样用低柱温,不易挥发的样品采用高柱温。 3、载气流速:载气流速是决定色谱分离的重要原因之一。一般讲流速高色谱峰狭,反之则宽些,但流速过高或过低对分离都有不利的影响。流速要求要平稳,常用的流速范围每分钟在10-100亳升之间。 4、固定相:固定相是由固体吸附剂或涂有固定液的担体构成。 (1)固体吸附剂或担体粗细:一般采用40-60目、60-80目、80-100目。当用同等长度的柱子,颗粒细的分离效率就要比粗的好些。 (2)固定液含量:固定液含量对分离效率的影响很大,它与担体的重量比一般用15%-25%。比例过大有损于分离,比例过小会使色谱峰拖尾。 5、进样:一般讲进样快,进样量小,进样温度高其分离效果好。对进液体样,速度要快,汽化温度要高于样品中高沸点组分的沸点值,一次汽化,保证色谱峰形不致展宽、使柱效高。当进样量在一定限度时,色谱峰的半峰宽是不变的。若进样量过多就会造成色谱柱超载。一般讲柱长增加四倍,样品的许可量增加一倍。对于常规分析,液体进样量为1-20微升;气体进样量为0、1-5毫升。
