第12楼2005/01/11
序号 名称 符号 单 词
1 氢 H Hydrogen
2 氦 He Helium
3 锂 Li Lithium
4 铍 Be Beryllium
5 硼 B Boron
6 碳 C Carbon
7 氮 N Nitrogen
8 氧 O Oxygen
9 氟 F Flourine
10 氖 Ne Neon
11 钠 Na Sodium
12 镁 Mg Magnesium
13 铝 Al Aluminum
14 硅 Si Silicon
15 磷 P Phosphorus
16 硫 S Sulphur
17 氯 Cl Chlorine
18 氩 Ar Argon
19 钾 K Potassium
20 钙 Ca Caldum
21 钪 Sc Scandium
22 钛 Ti Titanium
23 钒 V Vanadium
24 铬 Cr Chromium
25 锰 Mn Manganese
26 铁 Fe Iron
27 钴 Co Cobalt
28 镍 Ni Nickel
29 铜 Cu Copper
30 锌 Zn Zinc
31 镓 Ga Gallium
32 锗 Ge Germanium
33 砷 As Arsenic
34 硒 Se Selenium
35 溴 Br Bromine
36 氪 Kr Krypton
37 铷 Rb Rubidium
38 锶 Sr Strontium
39 钇 Y Yttrium
40 锆 Zr Zirconium
41 铌 Nb Niobium
42 钼 Mo Molybdenum
43 锝 Tc Technetium
44 钌 Ru Ruthenium
45 铑 Rh Rhodium
46 钯 Pd Palladium
47 银 Ag Silver
48 镉 Cd Cadmium
49 铟 In Indium
50 锡 Sn Tin
51 锑 Sb Antimony
52 碲 Te Tellurium
53 碘 I Iodine
54 氙 Xe Xenon
55 铯 Cs Cesium
56 钡 Ba Barium
57 镧 La Lanthanun
58 铈 Ce Cerium
59 镨 Pr Praseodymium
60 钕 Nd Neodymium
61 钷 Pm Promethium
62 钐 Sm Samarium
63 铕 Eu Europium
64 钆 Gd Gadolinium
65 铽 Tb Terbium
66 镝 Dy Dysprosium
67 钬 Ho Holmium
68 铒 Er Erbium
69 铥 Tm Thulium
70 镱 Yb Ytterbium
71 镥 Lu Lutetium
72 铪 Hf Hafnium
73 钽 Ta Tantalum
74 钨 W Tungsten
75 铼 Re Rhenium
76 锇 Os Osmium
77 铱 Ir Iridium
78 铂 Pt Platinum
79 金 Au Gold
80 汞 Hg Mercury
81 铊 Tl Thallium
82 铅 Pb Lead
83 铋 Bi Bismuth
84 钋 Po Polonium
85 砹 At Astatine
86 氡 Rn Radon
87 钫 Fr Francium
88 镭 Ra Radium
89 锕 Ac Actinium
90 钍 Th Thorium
91 镤 Pa Protactinium
92 铀 U Uranium
93 镎 Np Neptunium
94 钚 Pu Plutonium
95 镅 Am Americium
96 锔 Cm Curium
97 锫 Bk Berkelium
98 锎 Cf Californium
99 锿 Es Einsteinium
100 镄 Fm Fermium
101 钔 Md Mendelevium
102 锘 No Nobelium
103 铹 Lr Lawrencium
第46楼2005/07/08
ab. absolute 绝对的
addn. addition 添加
alc. alcohol 醇
alk. alkali 碱
amt. amount 量
A.P. analytically pure 分析纯
app. apparatus 装置
approx. approximate 大约
aqu. aqueous 水的
asym. asymmetric 不对称的
atm. atmospheric 大气压
av. average 平均的
b.p. boiling point 沸点
ca. about 大约
cal. caloric 卡路里
calc. calculate 计算
cf. compare 比较
chem. chemistry 化学
conc. concentrated 浓缩的
const. constant 常数
contg. containing 含有…的
compd. compound 化合物
C.P. chemically pure 化学纯
cryst. crystalline 晶体
decomp. decompose 分解
deriv. derivative 衍生
detn. determination 测定
dil. dilute 稀释的
distd. distilled 蒸馏的
e.g. for example 例如
elec. electric 电的
eq. equation 方程
equil. equilibrium 平衡
equiv. equivalent 等价的
et. al. and others 以及其他人
etc. et cetera 等等
evap. evaporation 蒸发
expt. experimental 实验的
fig. figure 图
hyd. hydrous 水的
ibid. in the same place在同一地方
lab. laboratory 实验室
liq. liquid 液体
L.R. laboratory reagent实验试剂
manf. manufacture 制造
max. maximum 最大的
min. minute 最小的
mixt. mixture 混合物
mol.wt. molecular weight 分子量
m.p. melting point 熔点
org. organic 有机的
ppm. parts per million百万分之一
ppt. precipitated 沉淀的
prep. prepare 制备
resp. respectively 分别地
sec. second 第二
soln. solution 溶液
solv. solvent 溶剂
sp.gr. specific gravity 比重
sq. square 平方
sub. sublime 升华
susp. suspended 悬浮地
tech. technical 技术的
Tech.P. technically pure 技术纯
temp. temperature 温度
vol. volume 体积
wt. Weight 重量
