液相色谱中荧光检测器,我设置了激发波长260,发射波长315,同时选择了all,激发波长从230到360,做多波长的检测。但检测过程中有一段出现A\D Overflow 的提示并且界面上的荧光灯由蓝色变为黄色。我应该如何调整?在线等高手指教,谢谢! 系统提示语为:The excitation wavelength 315nm is closer than 25nm to the emission wavelength 315nm.The excitation wavelenth range will be adjusted because (Fit Spectral Range)(special setpoints…)is ativated.
