一份日产负氧离子发生器(HAPPA-100)拆解分析报告
| SI 硅 | CR 铬 | FE 铁 | NI 镍 | CU 铜 | CO 钴 | MN 锰 | TOTAL 总含量 | 备注 |
AVE | .519 | 17.826 | 67.336 | 9.305 | 2.852 | .183 | 1.774 | 99.795 | 平均值
S.D | .155 | .291 | .724 | .174 | .221 | .045 | .310 | .146 | 标样修 正系数 |
ION | 1.023 | 18.985 | 66.770 | 8.777 | 2.486 | .172 | 1.788 | 100.000 | 修正系数 |
AVE | .660 | 17.612 | 67.502 | 9.319 | 2.629 | .163 | 1.709 | 99.595 | 平均值
S.D | .237 | .387 | .903 | .362 | .517 | .014 | .203 | .116 | 标样修 正系数 |
ION | 1.302 | 18.766 | 66.967 | 8.795 | 2.293 | .153 | 1.724 | 100.000 | 修正系数 |
SI 硅 | CR 铬 | FE 铁 | NI 镍 | CU 铜 | CO 钴 | MN 锰 | TOTAL 总含量 | 备注 | |
AVE | .428 | 16.755 | 73.266 | 8.025 | .195 | .180 | .812 | 99.660 | 平均值
S.D | .160 | .142 | .314 | .172 | .035 | .033 | .037 | .132 | 标样修 正系数 |
ION | .843 | 17.833 | 72.603 | 7.564 | .170 | .169 | .818 | 100.000 | 修正系数 |
序 号 | 规 格 | 备 注 |
FUSE | 保险丝 1A |
C0 | 104(0.01uF) |
C1 | 470uF/25V |
C2 | 104(0.01uF) |
C3 | 47uF/25V |
R1 | 330Ω |
R2 | 1.5K |
R3 | 72Ω(68Ω) |
R4 | 5.6K |
RLED1 | 330Ω |
RLED2 | 680Ω |
LED1 | 发光二极管 | 无灯 |
LED2 | 发光二极管 | 兰色 |
D1 | 1N4007 |
U1 | LM317 | 可调三端稳压IC |
VR1 | 500Ω | 可调电阻 |
PLUG-1 |
| 电源插座 |
FAN | MF52A-12(12VDC,0.09A) | 52×52mm |
