h04206010006
第1楼2021/11/23
https://www.law.cornell.edu/cfr/text/21/177.2450
后面应该就是测试项目啊
extractive limitations under the corresponding extraction conditions:
(1) Distilled water at 250 °F for 2 hours: Not to exceed 0.01 milligram per square inch.
(2) Three percent acetic acid at 212 °F for 2 hours: Not to exceed 0.05 milligram per square inch.
(3) Fifty percent ethyl alcohol at 160 °F for 2 hours: Not to exceed 0.03 milligram per square inch.
(4) n-Heptane at 150 °F for 2 hours: Not to exceed 0.05 milligram per square inch.
Insm_43df94da
第2楼2021/11/25
忘了写是问Fda均聚pom甲醛含量方法,看英文只写了限制,没有写方法
